Correct type of lug nut?
Old Aug 11, 2003 | 05:01 PM
djshawnee's Avatar
I have 18" Konig Caffienes on my Max and I had some new tires mounted and balanced today. I went to pick up the car and they said that they had some problems with the lugnuts and studs. One of the studs on the front driver side wheel broke halfway off when they took the lug nut off, and they showed me 2 more lugnuts from the front passenger wheel where the threads were in pretty bad shape. So, I have to pay for the replacement of some studs. They also told me to find some better lugnuts because the ones I have now don't go far enough in. They tighten alright, but they only go in about 5-6 rotations. I also need to be able to put the center caps on, so the lugnuts can't be very long. My lugnuts are just like the ones in this auction:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427328339
My question is.... should I get different style lugnuts? Or just replace the studs and just use the same style? Does everyone with aftermarket rims (that require the "acorn" style lugnut) only have to go in 5-6 threads before it being fully tightened? Or is it only my type of rim that is causing the trouble? I have to let the guy know tommorrow, so let me know quick. Thanks a lot!
Old Aug 11, 2003 | 09:25 PM
98SEblack's Avatar
just replace the studs, 5 or 6 full rotations from the lug nuts is enough to hold it on. if you are using the same lug nuts as in the picture, no problem
Old Aug 12, 2003 | 04:23 PM
djshawnee's Avatar
does anyone know where to get extended studs from?
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
leatherneck
Sep 30, 2015 09:16 PM
