Power Antenna Broke
Old Aug 12, 2003 | 08:26 PM
quickie's Avatar
Power Antenna Broke
Hey, the other day i was listening to my radio and backing up at the same time, and my antenna was up and it hit a low tree branch. Now the antenna mass is bent and wont go back down. So i took it off and jammed it back in the hole. Obviously im getting a lot of static on the radio. I was wondering what is the cheapest way of getting this fixed? Thanks
Old Aug 12, 2003 | 11:05 PM
Mishmosh's Avatar
You shouldn't have jammed it back in; it may be difficult to extract. First you need a new mast. You can get them off ebay. Then you need to remove the antenna bezel. That will allow you to extract the old mast once you power on the radio. After it is out, tell a buddy to turn the radio off as you feed the plastic cord of the new mast into the motor (with teeth in the same direction as the old one). Replace the bezel and you are done.
Old Aug 15, 2003 | 01:10 AM
Broaner's Avatar
2060lbs and falling...
Get a new mast. Search yahoo for "year" Nissan Maxima Anteanna Mast. Should be $25-35.
chisam14
Nov 6, 2018 08:56 PM
leatherneck
Sep 30, 2015 09:16 PM
