help! brake pedal still soft after replacing rear pads
Old Aug 13, 2003 | 01:19 PM
kenju4u's Avatar
I replaced my rear brake pads yetserday and had my front rotors cut and new pads installed a week ago. I am still feeling the soft pedal and is not firm as i think it should be when breaking. Is there something I am suppose to do after replacing the rear pads for adjustment?
Old Aug 13, 2003 | 01:53 PM
FazliS85's Avatar
Get Steal brake lines...they dont expand like the rubber ones and give you a firmer pedal. I think they run about a $100 and while ur at it change ur brake fluid.
Old Aug 13, 2003 | 01:57 PM
time2reup's Avatar
bleed them...
Old Aug 13, 2003 | 02:03 PM
kenju4u's Avatar
bleed them even if i just changed the pads? Acutually i just wanted to know if there was some normal procedure that i might have to do after installing new rear pads?
Old Aug 13, 2003 | 02:09 PM
FazliS85's Avatar
Rear brakes dont really do a lot of braking...Its the front ones that do almost 70% of all the stopping. Bleeding your brake system will offer better braking performance because old brake fluid losses its kick after a while. am i rite guys?
Old Aug 13, 2003 | 02:11 PM
time2reup's Avatar
no you shouldn't have to bleed them if you just changed pads...but with a soft pedal that would be my first action..
Old Aug 13, 2003 | 02:55 PM
KINGMAX's Avatar
sounds almost like you have a leak in the system, there is not enough pressure in there to let the pistons compress good. How is the fluid in the resivour?
Old Aug 13, 2003 | 03:13 PM
HondaKilLR's Avatar
Yes, you should bleed your system. If it's still soft, replace your master cylinder. If still soft, replace your slave cylinder---->Peace_
Old Aug 13, 2003 | 03:54 PM
kenju4u's Avatar
thanks! Acutally the fluid in the resivour is ok. I drove the car today about 70 miles and i think the pads just needed to get broken into...they are prefect now. the pedal is nice and firm now.
I did have get my master cylinder replaced once though when the car was still under warranty.
thanks for the help guys!
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
ef9
Aug 13, 2015 01:19 AM
