Maxima A/C Problem
Old Aug 16, 2003 | 12:43 PM
ssr's Avatar
ssr
Maxima A/C Problem
If Anyone can help.....I have a 95 Nissan Maxima with a A/C problem,
everything works except the comp. wont come on ...the pressures are good....if i jumped the relay it comes on and cools perfect...but theres no signal going to the a/c relay from one of the wires which goes stright to the ECU....I check all fuses replace the a/c control unit and a/c elec box under that control unit on top of the srs unit...still no signal/// has anyone have this problem before....
Old Aug 16, 2003 | 01:30 PM
pocketrocket's Avatar
Could be that your ECM A/C comp relay driver has quit. Or your A/C control unit. Or a wiring harness issue. It's not the easiest problem to troubleshoot.
Old Aug 16, 2003 | 02:21 PM
njmaxseltd's Avatar
It's probably a safety pressure switch in one of the refrigerant lines.
I believe there is a low pressure switch on the low side and a high pressure switch on the high side. Jump them to see which one is not letting the signal through to the compressor.
Lakersallday24
Nov 7, 2024 07:31 PM
Samedi
Aug 13, 2015 04:05 PM
acw
Aug 13, 2015 12:50 AM
Hawkeye61
Aug 12, 2015 06:45 PM
kirkhilles
Aug 8, 2015 10:53 AM
