warpspeed ypipes
Old Aug 17, 2003 | 09:19 AM
sk24iam's Avatar
warpspeed ypipes
whats the difference between the aluminized and the stainless steel?
Old Aug 17, 2003 | 09:42 AM
mzmtg's Avatar
Minister of Silly Walks
One is aluminized mild steel and one is made of stainless steel.
Old Aug 17, 2003 | 09:54 AM
RideTheMax's Avatar
The stainless steel won't rust
Old Aug 17, 2003 | 10:02 AM
sk24iam's Avatar
so the stainless steel one i better to buy right?
Old Aug 17, 2003 | 10:19 AM
joew's Avatar
yes.
Old Aug 17, 2003 | 10:31 AM
RI-Max's Avatar
how much is it again for a WSP Y
Old Aug 17, 2003 | 12:08 PM
n2oMike's Avatar
The aluminized is not going to rust through anytime in the next 25 years. The stainless might look a little prettier in 10 years, but Y-pipes stay hot enough that condensation is not a problem, and do not rust from the inside out like mufflers and tailpipes.
The original Y-pipe in my old 86' Pontiac is still holding up fine, and it wasn't even aluminized. If you want to spend extra money to be able to say you've got a stainless Y-pipe, feel free... but it's not necessary. When I purchased my Y-pipe, it was aluminized and cost $225 from WSP. It cam with all gaskets and bolts required for installation.
Good Luck!
Old Aug 17, 2003 | 01:45 PM
Dave B's Avatar
Not DAVEB the parts guy
Amen. Go to my homepage and you'll see my alumunized WSP y-pipe and there isn't an once of rust on it and it's been through 2 salty Kansas City winters. Stainless is do nothing for you other than lighten your wallet. Get the chaeper non-mandrel bent y-pipe too. Mandrel only make 1hp more (as seen with my own eyes on the dyno).
Dave
Old Aug 17, 2003 | 05:18 PM
Kevin Wong's Avatar
Dave
Hey Dave, is that 1HP peak, or are there other gains throughout the RPM band? I'm thinking about trying Warpspeed's Y-pipe over my current Stillen design.
Old Aug 17, 2003 | 08:45 PM
Dave B's Avatar
I believe no power was gained at peak, just after 6000rpms. The test car was a bonestock 96 GLE. He dynoed with the non-mandrel and then the mandrel a month later. Same dyno and similiar conditions.
I use to have a Stillen Y-pipe and sold it for cheap because the flex section was going out. I ended up picking up the WSP non-mandrel because it was cheap and had the lined flex. It is significantly more quiet than the Stillen plus I think it gained me a lot more power. With my Stillen Y-pipe I made 174fwhp and 192fwtq. I then dynoed (on the same machine) my WSP y-pipe and newly installed UDP. My car made 183fwhp and 193fwtq with huge gains after 5000rpms. Some parts gained over 10fwhp and 10fwtq. I know for a fact that my UDP didn't gain that much power.
Dave
Matt93SE
May 24, 2019 02:58 PM
lrb6805
Sep 30, 2015 08:12 AM
lrb6805
Sep 17, 2015 04:49 PM
Samedi
Sep 3, 2015 01:07 PM
