Regarding dealership, and hazard + r. defrost switch
Old Aug 18, 2003 | 08:31 PM
HarrisH's Avatar
I recently had a system installed in my car, and I was reading up on the illumination of the hazard and rear defrost switch because I know that both illuminated before. I was doing some reasearch and found out that the bulbs placed inside both switches are quite sensitive and when people take apart their dash to work on stuff, or install things, the bulbs move out of place. One guy actually tapped his dash the left side of his dash, and got the switches to work. Since I don't have much of a choice and am real **** about my car I took my car to the dealership, I actually took to the dealership after my trusty mechanic checked it out. Both switches are doing their job, so they're obviously getting power. However; the orange light, nor the illumination caused by the bulbs is working. So this would result in the bulbs being misplaced inside the switch and this probably happened during the install since they're ovbiously so fragile. To make a long story short I'm out 220 dollars for the switches and labor thanks to the stealership. I was like ok whatever just do it. So this Friday they're going to put in the switches. Sucks
Old Aug 19, 2003 | 11:59 PM
maxima_se007's Avatar
220, you can get the vent and clock trim WITH BOTH OF THOSE SWITCHES AND THEIR BULBS for like $20 on eBay. Hopefully you haven't done it already and get this message before you do. Good luck.
Old Aug 20, 2003 | 05:59 AM
sidewinder740's Avatar
Re: Regarding dealership, and hazard + r. defrost switch
I have the same problem as you and it bothers me as well. Let me know if getting new switches solves the problem, but are they really that expensive? Did you JUST pay for two switches and labor? If so, I could learn to live with it.
And maxima_se007--I don't see those switches on Ebay. Are you sure it's on there?
Old Aug 20, 2003 | 09:53 AM
HarrisH's Avatar
I'm hoping it is the dam switches, and the reason I'm paying the 220 (which I have) is to make sure that Nissan is FULLY RESPONSIBLE. In other words they have to make them work no matter if it's an electrical problem, or switch problem. I read on a previous thread relating to the subject that the bulbs are positioned weird hence when people take out their dash 9 times out of the 10 those switches stop illuminating. I will keep you informed.
Old Aug 20, 2003 | 10:03 AM
jetblack5spd's Avatar
DONT DO IT PLEASE. THE SAME THING HAPPENED TO MY SWITHCES. I FIXED THEM FOR 3 DOLLARS. HERES THE RADIO SHACK PART NUMBER. DO IT YOURSELF. I HAVE AN EXTRA SET OF HAZARD AND DEFROST SWITCHES. THE LIGHTS DONT WORK IN THEM BUT IF YOU WANT I CAN FIX EM FOR YOU AND SHIP THEM OUT. ANYWAY HERES THE PART NUMBER. #7219 MICRO LAMP 12 VOLTS/60mA/WIRE TERMINAL BASE.
Old Aug 20, 2003 | 12:24 PM
I'll buy them for $30. Are the switches in good condition (i.e. no scratches on them or anything)? And how can you verify that they'll work once you fix them?
Old Aug 20, 2003 | 08:19 PM
HarrisH's Avatar
If the switches do their job I.E. putting on your blinkers, and defrosting your rear window and just not illuminating then would this possibly result in a short of the wires? I mean how lose are the bulbs in the switches in them? I mean would taking apart the dash result in the bulbs being misplaced inside the switch. I can still take my money back. Help me out here
Old Aug 21, 2003 | 07:41 PM
the bulbs in the switches are not loose. they are just burned out or defective. i checked all the continuity of the bulbs before i replaced them to make sure. none of them were good they were all burnt out. easliy raplaced them. if you want me to send em' out to you sidewinder i can take a pic of them for you lit up and not lit up. or if your in the new york city area you could see them for yourself. or if you want them you could have them harris for 40 bucks
Old Aug 21, 2003 | 09:11 PM
I'll buy if you can guarantee me that they'll work. $40 PayPal... Can you e-mail me some pics?
Old Aug 21, 2003 | 09:17 PM
ill try to get some pics to you as soon as possible. you can talk to me on aim (aol instant messanger) if you want at fubiotch7
Old Aug 23, 2003 | 09:36 AM
HarrisH's Avatar
*Update* First off my father got laid off pray that he finds a job , I picked up the parts off of Nissan, and I was like I'll install them myself, so I did and they're working, so yes it is the bulbs that go out, and yes I should've bought them off of you .
Old Aug 23, 2003 | 11:03 AM
mo'max's Avatar
Defogger and Hazard Switch bulbs
HarrisH -
I've repaired mine before for about $1.50.
http://test.maxima.org/showthread.php?t=46445
I hope this link works. It should put you on the test site since the search function is disabled right now. If it doesn't, do a search on me on the test site.
good luck.
Old Aug 23, 2003 | 02:58 PM
you win some you lose some harris, i still have the switches if anyone wants me to fix them and buy them
20 bucks sounds fair. dont you think?
gavin68
Sep 18, 2021 12:36 PM
D Mason
Jun 21, 2016 04:43 AM
bigfrank
Oct 1, 2015 12:51 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
