Bypass valve negate CAI gains?
Old Aug 19, 2003 | 08:38 AM
ohannon7's Avatar
I've read it does, i've read it dosent. Some people say the test
that shows that the bypass valve negates any gains from the CAI are not accurate b/c the tubing was like 4ft long. I think it was done on an Acura NSX?
Well im curious b/c i think i need to order one b/c a buddy of mine w/ one of those hatchback focus's and a CAI w/ no bypass valve just hydrolocked his engine.
SO: Does the bypass valve negate any gains you would have recieved from the CAI (in other words, is it not even worth gettin a CAI if you are gonna put a bypass valve on it?)
Old Aug 19, 2003 | 01:22 PM
ohannon7's Avatar
c'mon now....no one has a bypass valve??? or just no opinions
Old Aug 19, 2003 | 07:03 PM
sryth's Avatar
Was he playing speedboat racer when he hydrolocked?
Old Aug 20, 2003 | 07:09 AM
ohannon7's Avatar
No i dont believe so. but ive heard of other people hydrolocking their engine. Last week i read a post from a guy that said his friend hydrolocked his celica's engine.
Im pretty sure it only takes a very small amount of water to do it
Old Aug 20, 2003 | 09:14 AM
Dave B's Avatar
Not DAVEB the parts guy
Why worry about it unless you're slammed to the ground and typically drive thru 8+" puddles of water. If it bothers you that much then just run a hybrid intake. The gains are the same between the two.
Dave
Old Aug 20, 2003 | 09:28 AM
ohannon7's Avatar
I guess id feel safe if everyone else on here w/ CAI's dont have a bypass valve. I just dont know if anyone else is using them. As far as being slammed to the ground...im lower than my neighbors focus who hydrolocked his engine
Old Aug 20, 2003 | 09:44 AM
97MaximaSE's Avatar
ive had my place racing CAI on for 4 years nows in new england with no problems what so ever. ive never heard of anyone on this board whos gotten a hydrolocked engine with a cai
Old Aug 20, 2003 | 10:18 AM
ohannon7's Avatar
and you dont have a bypass valve on it?
Old Aug 20, 2003 | 10:29 AM
Dave B's Avatar
Actually Russ hydrolocked one of his 4th gens with a CAI driving thru a flooded out area.
Take a measurement of where your filter sits and determine how much water you can drive thru. Personally, driving thru water any deeper deeper than just 3" is completely stupid. Way too make things can happen.
Dave
Old Aug 20, 2003 | 11:14 AM
Stephen Max's Avatar
Re: Bypass valve negate CAI gains?
I've got a cai and no bypass valve, and yeah, I have to admit, I get a little nervous when we get torrential rains here. I don't usually drive in flood conditions, but if I had to, I'd just disconnect the upper end of the cai and let the engine breathe unfiltered air for a while.
Old Aug 20, 2003 | 12:15 PM
jetblack5spd's Avatar
let the engine breath unfiltered air for a WHILE??????? why would you do such a thing?
Old Aug 20, 2003 | 12:33 PM
So as not to risk hydrolocking the engine when it floods. I thought that was clear from context. For instance, if I got caught at work and had to drive home with water pooling up on the highway and in low spots, I would much rather run the engine without the filter than risk a hydolock.
Besides, what's the problem? There's not going to be any dust in the air after a torrential downpour, and low flying birds and whatnot will be caught in the mafs screen.
Old Aug 20, 2003 | 05:10 PM
nismos14's Avatar
§è~® f®ÈÄk
at the birds in the screen, the bypass valve probably works, but im not sold on it, good luck, i think u should just run a mid pipe, forget about the whole cai
Old Aug 20, 2003 | 05:37 PM
ny96max's Avatar
this has been discussed since the days when PlaceRacing made the first CAI for the max. There is NO need whatsoever for a bypass valve on a maxima CAI, the filter element is high enough up in the fender to be protected from even mild flooding
Ant
Old Sep 12, 2003 | 10:44 PM
s0ber's Avatar
Just have a spare cheap filter in the trunk... so when you see water just take off the cai pipe and put on that filter
<--- sorry am i late? how old is this thread
Old Sep 13, 2003 | 02:02 AM
SXN's Avatar
SXN
lots of water, and an intake sitting low in a relatively vulnerable place... it makes sense. at the same time its russ so i dont care
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
Marc2theMax
Sep 28, 2015 08:13 AM
Sep 27, 2015 08:37 AM
