amplifier cutting out when accelerating...
Old Sep 12, 2003 | 03:46 PM
maxima_se007's Avatar
I have an alpine mrp-m350 amp added on to my stock bose system, and lately it will cut out when accelerating. I can sometimes jsut barely touch the gas and it will turn off for like 5-6 seconds. A few months ago, the amp would cut out when going over bumps, while the stock system would keep on playing, no skips or anything. I checked all the connections and wires, and it is all great. I sent the amp to alpine and they told me everything was fine. I got if back and it worked ok for a while, but now it turns off while accelerating even though the bose still keeps on playing. Could it be some sort of voltage regulator that has gone out? How can i fix it and hass anyone had anything similar happen. This amp does not draw alot of power and is a class d, so i am stumped. any help would be greatly appreciated.
Bryan
Old Sep 12, 2003 | 04:52 PM
nismos14's Avatar
§è~® f®ÈÄk
loose connection, check all ur wiring and make sure its all connected properly, its probably something from the signal input, or behind ur head unit
Old Sep 12, 2003 | 05:55 PM
driver824's Avatar
CHECK THE AMPS GROUND WIRE!!!!!! i use the nut that holds the rear strut in. if u use anything with paint on it...try sanding the paint off. hope this helps. also, check the remote wire.
Old Sep 12, 2003 | 08:01 PM
s0ber's Avatar
should of posted this in the audio/electronics forum... more people would answer there.
Old Sep 13, 2003 | 02:21 AM
SXN's Avatar
SXN
this is a theory i need to run past everyone... using more voltage for the higher RPMs/more sparks. do you have a good battery? are all your connections (power and ground) good? did you use good gauge wire and stuff? Does your sub have a cap?... just a theory
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
EdRomo86
Sep 12, 2015 07:49 PM
