Engine and fuel system cleaners
Old Aug 19, 2003 | 03:31 PM
SaNdMaN's Avatar
I recently bought a 96 Maxima with just under 70k miles. I did a transmission flush, changed oil (put synthetic), etc. Now my question is should I put some kind of engine and/or fuel system cleaner in it? Which brand would you recommend?
Old Aug 19, 2003 | 03:38 PM
RobUsaf81's Avatar
I recommend valvoline fuel system cleaner. Ive used it and i definetly felt a difference as did a friend of mine who drives a focus. It seems to work pretty well and i put a bottle in every oil change or so.
Old Aug 19, 2003 | 03:47 PM
dwapenyi's Avatar
Just drive on the highway real hard It'll clean your feul system with no additives
DW
Old Aug 19, 2003 | 06:16 PM
maximomo's Avatar
Re: Engine and fuel system cleaners
Use Outlaw fuel system cleaner and Octane booster. Comes only in a 32 oz. can. Use it through two full tanks of gas.
Also use Marvel Mystery oil. At least 6 oz. in your gas tank.
Marvel is a high detergent oil that is great on valves, injectors,
cylinder walls, everything.
Helps burn the carbon off the whole combustion chamber. For those times when your driving like on the highway!
Old Aug 19, 2003 | 06:17 PM
slizan99's Avatar
BG is prolly the best there is.
Old Aug 19, 2003 | 08:47 PM
SaNdMaN's Avatar
hmm... now i don't know which one to choose
Old Aug 19, 2003 | 09:17 PM
95BLKMAX's Avatar
I can tell u that the small bottle of Greased Lightning Engine Treatment is the best. I hear Mystery Oil is good, but haven't tried it. Greased Lightning will smooth out ur engine, and u can feel at any engine speed. It's like silk. But after about 75k miles, nothing helps ur engine's internals stay clean like a Motor Flush (Advance/ Discount Auto Parts). It'll disolve all the gunk off of ur valves and oil pan (warning: Motor Flush is dilluted Diesel w/ cleaners in it. Do not use at every oil change. Allow at least 15k miles bet'n flushes)
For fuel, if u've never done it, use Greased Lightning. I promise it's the strongest cleaner u can find. But for that same reason, u shouldn't need to use it more than 2x a year. In bet'n u can use STP Consentrated Fuel Injector Cleaner (the black bottle), very effective cleaner. I use it every month and a half. But again, if u've never done it or can't remember when was the last time u cleaned the injectors, use Greased Lightning.
Old Aug 19, 2003 | 09:49 PM
Jatan's Avatar
http://forums.maxima.org/showthread....hreadid=234313
http://forums.maxima.org/showthread....hreadid=229698
http://theoildrop.server101.com/cgi/...=5;t=000664;p=
http://theoildrop.server101.com/cgi/...DaysPrune=1000
Old Aug 19, 2003 | 10:38 PM
maxima_se007's Avatar
dont mean to ***** up yyour thread, but is flushing your engine bad for high mileage cars and their seals-just something I heard. I use STP super concentrated fuel injector cleaner every month or two and it seems to help a bit.
Old Aug 19, 2003 | 11:10 PM
RobUsaf81's Avatar
What would high mileage on a maxima be though? I have 88K and id like to change to synthetic oil and flush my engine but im a little hesitant cause i have yet to get a unanimous answer.
Old Aug 20, 2003 | 02:34 PM
96_Infiniti_I30's Avatar
read this http://www.envirolution.com/index.htm
btw i used amsoil engine flush and i had no problems.it worked fine.
BkGreen97
Apr 2, 2016 05:47 AM
03VQMAX
Sep 5, 2015 03:47 PM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
