My car hard to start
Old Aug 20, 2003 | 09:23 PM
GXEmaxima96's Avatar
i have a 1996 maxima gxe, I crank my car more than five time before it will start also it sound like is of timing but its not when it start it run fine, the engine was replaced could be any sensor or any ground please help me.
thank you all
Old Aug 20, 2003 | 11:31 PM
MaXaZoR's Avatar
I had the same problem w/ my maxima (no check engine light)took awhile to crank, but after worked fine...it was a huge pain in the *** to fix,
1.) used injector cleaner (not it)
2.) replaced fuel filter (not it)
3.) replaced spark plugs (not it, but helped)
4.) finally hooked it up to a computer and noticed that when it was cranking you are supposed to get a 180 degree crank radius...i would get between 87 and 140...so i thought i would be the crank sensor (not it)
5.) FINALLY contacted nissan and they said that it could be a bad ground inside my transmission (hard to believe)...but $500 later it proved to be the problem
Good luck
Old Aug 20, 2003 | 11:39 PM
97blackSE's Avatar
what was the problem? it just took a while to turn over?
my car doesnt start right up
it takes like 2 seconds...
is this a problem?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
