ECU Error Code 1005 Can anyone help?
Old Aug 21, 2003 | 09:01 AM
enjetek's Avatar
1005
1005 is EGRC Solenoid valve
The majority of my information about Diagnostic Trouble Codes comes from my '99 Maxima factory service manual. Unfortunately, DTC 1005 is not in that book. Starting in '99 the Maxima engine uses a step-motor type of EGR valve and with that change, the DTCs changed.
The Chilton and Haynes manuals provide a little information about the EGR Solenoid Valve.
The test procedure for this part is found in the Chilton repair manual (page 4-11) and the Haynes repair manual (page 6-20). Test the valve and replace if necessary.
This malfunction is not an emergency but should be resolved fairly soon (7-10 days). An inoperative EGR valve may result in engine pinging and a variety of driveability complaints.
I looked it up and that is what I received. Can someone tell me how this can be fixed and how much it would cost? Thanks.
-Michael
Old Aug 21, 2003 | 11:53 PM
enjetek's Avatar
Can anyone help? This is the EGR problem that a lot of other poeple are having also.
Old Aug 22, 2003 | 03:42 AM
MIXXMAX's Avatar
In my '95, this was a fairly inexpensive part. I paid about $65.00. Replacing it was fairly easy, too. If you look near the transmission dipstick tube, there is a small, green connector with three valves coming out of it. This is the EGR solenoid valve. I found it easier to remove the air filter assembly to gain access to it. The hoses were hard to remove, so I just cut them and put new ones on. Only air passes thru them, so nothing major to worry about. I'm not sure about the location in your particular year, but it should be in the vincity (sp.?).
Old Aug 22, 2003 | 08:13 AM
enjetek's Avatar
thanks. i will check it out and hopefully it will fix the problem instead of spending 300+ to fix the egr solenoid. i will post my results.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
