Prolly been asked, but another MEVI ?
Old Aug 23, 2003 | 12:42 PM
Mad-MAX_SE's Avatar
Still kickin'
i bet this has already been asked before, but with the MEVI, when it changes over, does it sound like a honda hitting v-tech?. what i mean is, is there a change in the sound of the intake, or does it stay the same?
Old Aug 23, 2003 | 02:54 PM
Nismo's Avatar
changes to a higher pitch tone like waaaaaaaaa*vi opens*AAAAAAAAAAAAAAAAAA
Old Aug 23, 2003 | 03:42 PM
BSwithTF's Avatar
If your using a mid-pipe in your intake you can hear the changeover. I went back to the stock resonator box and I can't hear it change over anymore. I kinda miss it !!!
Old Aug 23, 2003 | 04:34 PM
Nealoc187's Avatar
SLOW
I can't hear mine switch over, never have been able to. I can tell whether its switched over or not by the sound it makes above about 6000rpm, but I don't notice a tone change when it switches.
Old Aug 23, 2003 | 05:44 PM
Sprint's Avatar
i have a y pipe and a straight pipe and i can never hear the switch over
Old Aug 24, 2003 | 02:41 PM
matty's Avatar
Get next to a center mediun on a highway with the windows open, and you will hear it
the intake sounds are closer together..
-matt
Old Aug 24, 2003 | 05:07 PM
Mad-MAX_SE's Avatar
Still kickin'
so there is a noticable, at least for some, change in sound? i have a frankencar intake, so would i be able to hear it with that? the only reason i'm asking is because a good friend of mine has an SI and i love the sound it makes when it changes over. any more input would be great.
Old Aug 24, 2003 | 05:12 PM
matty's Avatar
It wont sound like an SI
-matt
Old Aug 24, 2003 | 07:55 PM
JAY25's Avatar
hearing it would be impossible at full throttle, but you can feel it.
Old Aug 24, 2003 | 08:08 PM
BSwithTF's Avatar
It doesn't sound like VTEC kicking in, but you can hear the tone change. Usually only if you're really listening for it.
Old Aug 24, 2003 | 08:30 PM
Sprint's Avatar
-matt
been there.. done that..
nope.. you won't hear ****.. i have turned my radio off.. i have tried it with the windows open.. windows closed.. blown y pipe.. fixed y pipe.. nope .. no sound.. i think people are confusing the slight hesitation and pull with sound. You don't hear anything.. you just feel it slightly kinda like a jerk..
Old Aug 24, 2003 | 08:55 PM
Mad-MAX_SE's Avatar
Still kickin'
ok, i was hoping it would, but if it doesn't then it doesn't. Also, i know i've got to stop the honduh related questions, but instead of the Harlan RPM switch, could you use a v-tech controller since they're both selenoid based controllers? the only reason i'm asking is because he has the V-AFC, and can get me one for dirt cheap. thanx for all the help guys!
Old Aug 25, 2003 | 07:13 AM
Mad-MAX_SE's Avatar
Still kickin'
anybody?
Old Aug 25, 2003 | 07:33 AM
JeffesonM's Avatar
living out of a maxima...
I can't really hear mine, but others riding in my car have said they can.
Old Aug 25, 2003 | 08:00 AM
96BLUMAX's Avatar
I wouldnt try and put vtech in a maxima.
Old Aug 25, 2003 | 08:27 AM
Dave B's Avatar
Not DAVEB the parts guy
Hmmmmm....I could hear mine plain as day as long as you have a MIDPIPE and a 5000-5100rpm switchover. To my ears, it's sounds like the VTEC cam engaging on a stock CL/TL-S. If you have an auto, the changeover won't be as apparant. When I dynoed (hacked airbox, midpipe), the switchover was loud and everyone's eyes in the shop were when the tach swung past 5000rpms. I did notice that the higher the rpm switchover, the less you can hear the noise. At a 5400rpms switchover, I could barely hear it which probably means it's working better hence the lack of resonance (noise).
I put on my resonator between the TB and MAF and now I can barely hear anything which kind of sucks because I liked the sound and it also told me it was working.
Dave
Old Aug 25, 2003 | 03:22 PM
Mad-MAX_SE's Avatar
Still kickin'
wow, thats really different from from what others have said. so dave or anybody else with the MEVI, would it be possible to use a V-AFC to control the changeover point?
Old Aug 25, 2003 | 07:09 PM
Mad-MAX_SE's Avatar
Still kickin'
well aren't we a bright one...of course i know you can't do that. although...just kidding.
Old Aug 25, 2003 | 09:30 PM
Dave B's Avatar
Won't work. The system uses an RPM signal to tell the MAP sensor to open and apply vacuum to the actuator rod which in turn opens/closes the butterflies. The V-AFC would be useless....I think.
Dave
Old Aug 25, 2003 | 09:35 PM
nismology's Avatar
MAP as in Manifold Absolute Pressure sensor?? I didn't think Maximas had those.
Old Aug 27, 2003 | 01:08 PM
Mad-MAX_SE's Avatar
Still kickin'
but the v-afc changes the rpm point for the v-tech change over, so it would have the same rpm signal that the harlan gets right? v-tech is controlled by a selenoid right? i thought that the MEVI was controlled via a selenoid as well...i guess i thought wrong. thanks for the help Dave!
litch
123
Jan 4, 2024 07:01 PM
Stagnet04
Oct 11, 2015 08:16 PM
