pop truck w aftermarket alarm
Old Aug 24, 2003 | 09:52 PM
joew's Avatar
Does anyone know how to make the truck pop with an aftermarket car alarm?
Old Aug 24, 2003 | 10:53 PM
ivelweyz
Like a pepsi truck, the new Pepsi Vanilla truck in the commercial is hillarious.
Seriously though get an alarm that has a TRUNK opener and that's it...
Old Aug 25, 2003 | 12:57 PM
joew's Avatar
ok thanks.
Old Aug 25, 2003 | 04:03 PM
ThurzNite's Avatar
depends. what trunk release do you have now? a lever or a button? if button, you'll just need to wire up a relay. If lever, you'll need a solenoid and relays.
Jae
Old Aug 25, 2003 | 04:59 PM
ivelweyz
guessing stock, what others are there???
Old Aug 25, 2003 | 05:08 PM
tzmanles's Avatar
I have the Viper installed by Don...it releases through the AUX on the remote
Old Aug 25, 2003 | 05:54 PM
joew's Avatar
I have Clifford. I don’t know if it is button or lever. What do you think I need to get?
Jae
Old Sep 2, 2003 | 04:12 PM
Pearl96Max's Avatar
I tend to get a bit irritable
What year is your max? Is there a button on your door to release the trunk? OR is a lever that you pull up in front and to the side of the drivers seat. If its the button then you just need to connect the wire from your aftermarket alarm for the trunk release, and use a relay.
--Don
Old Sep 2, 2003 | 09:54 PM
joew's Avatar
Ah, I see what you folks mean by lever. I thought it’s in the trunk. My max is 97 and I have a lever. What do you think I should do then?
--Don
Old Sep 2, 2003 | 11:43 PM
Chunger's Avatar
My other car is a Hybrid
Lever = no electric solenoid
You need to get an electric solenoid and have it installed... then it's simple to wire the alarm's AUX output to activate the relay powering the solenoid.
If you already had the push button release on the door, then you just ground a wire running outboard of the driver's seat.
Old Sep 3, 2003 | 08:57 AM
joew's Avatar
ok, thanks.
Old Sep 3, 2003 | 05:26 PM
Pearl96Max's Avatar
Are you sure that the lever is for the trunk and not the gas? I have only seen '95s with the lever. Check on your door for a button.
--Don
Old Sep 3, 2003 | 08:17 PM
DaThrillr's Avatar
i have a lever on my car ...1998 Gxe w/o C&C ... the woerd part is in my door there is a wire for the button ... im not sure if there is a solenoid to open it.. or maybe everything has to be added
Old Sep 3, 2003 | 08:40 PM
joew's Avatar
Ya, my max have a lever. When I push down the lever, it’s for the gas door and when I pull the lever, it’s for the trunk.
--Don
Old Sep 3, 2003 | 09:50 PM
Pearl96Max's Avatar
Must be a GXE or C&C thing....
-_Don
Old Sep 4, 2003 | 08:44 AM
joew's Avatar
nop, mine is 97 SE
-_Don
Old Sep 4, 2003 | 09:36 AM
Pearl96Max's Avatar
Originally Posted by joew
nop, mine is 97 SE
But like I said....GXE OR C&C, So now I guess it would be the C&C thing.
--Don
Mahmuth
Aug 16, 2024 08:23 PM
D Mason
Jun 21, 2016 04:43 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
