Opening the spoiler brake light casing
Old Feb 10, 2001 | 08:52 AM
hlh0501's Avatar
I removed the brake light from my spoiler, because the guys at the local car audio shop said it take it out, and find a hole in it, and spray in the hard foam stuff that they use in houses.... the insulation stuff that you get in a can? There are no holes in mine to spray it in.... and I can't seem to be able to get the casing open on this thing.
Has anyone dealt with this before? Should I drill a few holes and then crazy glue little rubber seals back over them or something??
Old Feb 10, 2001 | 12:33 PM
hlh0501's Avatar
I decided to drill 5 holes, evenly spaced across the top of it (chose the top b/c you could see what you are doing better). I then used a can of spray foam insulation from the hardware store, and filled the back half of the led board, so it can't move. I am still waiting for it to finish drying/expanding. Some of it expanded over to the LED bulbs, but oh well, thats part of life I guess. The insulation will seal the holes, and then I am putting electrical tape of the holes too - and then finally some very thing sticky backed foam tape, so that when I screw it back in there is no way that the plastic casing can vibrate against the metal spoiler.
I'll let you all know how it sounds.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
