help!!! transmission problem?
Old Sep 3, 2003 | 03:42 PM
wrongway15's Avatar
my car is (usually) not getting very much power from the engine. I will be driving and when i hit the gas, my engine revs (tach flys) , but the car doesnt accelerate very fast. sometimes it takes forever to get to highway speeds. I could be at 6000 rpms in third doing about 30 mph. i had the clutch master and slave cylinder replaced by merchants auto about a month ago. nissan dealership said it may be faulty parts they installed (i went in for ecu codes). took the car to merchants and they say it may be the tranny is bad?
i know its not the clutch because that was done recently (and grabs hard when the car runs fine). the clutch peddle does get really firm and grabs high when i have this problem. it usually occurs after driving the car a few time that day (short trips)
i guess i have to go back to nissan. do you guys have any clue what may be up.
my ecu was throwing map sensor and knock sensor codes, but nissan said that shouldnt cause the problem.
Old Sep 3, 2003 | 04:27 PM
nismos14's Avatar
§è~® f®ÈÄk
get the knock sensor problem fixed, and i bet you this problem is the new clutch, does it ony happen after you've been driving for a bit? or does it happen right away? like right when u start the car or when u have been driving a bit
Old Sep 3, 2003 | 06:55 PM
wrongway15's Avatar
after a bit of driving, like when im running around town, ill start up after a few short trips and then thats when it happens
what could be wrong with the clutch?
i am getting the knock sensor fixed, but it may be a week or so
Old Sep 4, 2003 | 07:52 AM
wrongway15's Avatar
no one?....nismos?
Old Sep 4, 2003 | 08:41 AM
kushane's Avatar
Sounds like the classic symptoms of a slipping clutch. Either the clutch disk itself is worn out or not clean where it's slipping OR could be something with the pressure plate not pushing the clutch disk hard enough.
Just my $0.02
Old Sep 4, 2003 | 08:55 AM
BKLYNHEDZ's Avatar
Same problem happened to me when I did my conversion. Yo have to adjust the yoke on the master cylinder. For some reason after you start driving for a while you start losing pressure in the hydralic system because air starts getting in the lines. Take it back to them and have them check the master cylinder I can bet you thats the problem.
Old Sep 4, 2003 | 02:57 PM
nismos14's Avatar
§è~® f®ÈÄk
yeah definately sounds like either a bad clucth install or lots of air getting in the lines some where, have it checked out soon, wouldnt want you to have to shell out for a new clutch again!
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
