EGR no more?
EGR no more?
Has anyone heard of a mod to remove the egr system? I was talking with a guy that just swapped an SR20 into his 240 and a friend of his suggested removing the egr system. He said it would do away with alot of the vacuum hoses. Anyone have any idea?
Originally Posted by slammed95
All it will do is get rid of a few small hoses. Won't pass smog, probably won't run right, and CEL most likely will turn on.
When you're at WOT the egr isn't activated anyways, so it's useless.
"EGR only improves part throttle performance and gas mileage. At part throttle, the EGR system reroutes a small amount of the exhaust gas back into the intake. Since exhaust gas has already been burned, it doesn't burn again when mixed with the air/fuel mixture. Instead, it merely displaces some of the air molecules in the combustion chamber. As a result, combustion chamber temperature and fuel requirement are both reduced. Since a cooler combustion chamber decreases the chance of detonation, the ECU doesn't need to pull out timing. Therefore, you would get good performance and gas mileage.
There is no EGR at idle. Your idle will be rough if your EGR system feeds exhaust gas back into the intake at idle. Likewise, there is no EGR at wide open throttle. At wide open throttle, you want the maximum number of air molecules entering the combustion chamber in order to make maximum power.
In short, there is no need to disable the EGR system for power because it's not on at WOT anyway."
Looks like I spoke too soon. Sorry about that. Just did some looking around (googled it up
) and it seems that you were right.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
shilov
02-19-2024 09:40 PM
KabirUTA13
19
10-17-2015 02:15 AM
JoshG
51
09-21-2015 10:41 PM
