Car pulls to either side, what gives...
The car (95SE w/ 63K miles) has been aligned in the
past 6 months. Tires are rotated on a regular basis
and the air pressure seems to be even.
The problem occurs when I turn to the left OR right
and the car refuses to steer back to "dead center".
After a turn, I let go of the steering wheel and the
car does not return back to straight-on steering.
What could this be? Suspension bushings wearing out?
I have H&R w/ Tokicos, on for a about 10K miles and
all hardware was replaced.
Any help would be appreciated.
PeteMo
95SE
PeteMo
95SE
Steering Problem
PeteMo
95SE
PeteMo
95SE
I just had my alignment and my car drifts way to the right. I have to hold the steering wheel to the left about 5-10 degrees to keep it going straight. It's all good I'm used to it. My tires are wearing evenly.
Re: Petemoe
Originally posted by sinewave
It sounds like the caster is off. I would take it back to the front-end shop.
Comments about the comments...
Thanx for the input, but the problem still stands.
Here is some more data to go with what has already
been said.
- Strut bearings are new, 10K miles on them. So
I rule them out.
- No mods to change the caster, so that may not be
the problem
What I am wondering on is whether or not tightening
of the nut on the top of the strut (in the engine bay)
tower will do anything to help this problem? Not the
group of 3 nuts that the FSTB connects to, it is the
center nut. Will this help?
Thanx!
Pete Mo
95SE
been said.
I rule them out.
the problem
Thanx!
Pete Mo
95SE
Re: Comments about the comments...
been said.
I rule them out.
the problem
Thanx!
Pete Mo
95SE
been said.
I rule them out.
the problem
Thanx!
Pete Mo
95SE
Don't know if this will help but I had a heck of a time identifying a similar problem plus a rubber on rubber noise when I would turn the wheel at very slow speeds. Turned out to be the wrong strut isolators.
my max too...
the exact same thing happens to my max too. when i turn the wheels stays slightly in the direction i turned from, i have to center it manually. also, when driving it also does this. sometimes on the freeway, the car will slightly pull in either direction, totally spontaneous. gotten used to it all though. btw, i have bone stock 97 gxe.
Thanx!
Pete Mo
95SE
Thanx!
Pete Mo
95SE
my car also pulls to either side randomly, but only when driving on uneven road. It pulls pretty hard that i have to hold on to the steering wheel pretty hard all the time just in case it pulls again. It kinda feels like playing Daytona USA or similar arcade, the wheel pulls randomly. It started to happen right after i lower the car and put on 18" wheels. My friend who just got 18"s also have this problem. we both did alignments, so i am guessing is normal for 18"s? any one?
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
BassAddictJ
Aug 4, 2015 11:38 AM
