Fuel Injector Replacement...OEM vs. Venom
Sep 10, 2003 | 04:35 AM
My '95 Max SE has 110k on it and I've dropped two injectors (bad coils) over the last 4 months. The second one just dropped. When the first one dropped, I didn't have the $$$ to replace the whole set, so I'm going to replace the whole set.
OEM are about $750 for the set. Summit Racing has a set of Venom Injectors for about $550 - apparently they flow about 5% more than the OEM.
Has any one tried these in a Max? Any problems, other than slightly decreased fuel mileage?
Will the 'puter adjust the injector timing to account for the 5% higher fuel flow rate?
Thanks!
Sep 10, 2003 | 04:45 AM
Here's the web site
http://store.summitracing.com/defaul...ctor&x=13&y=10
Sep 10, 2003 | 05:21 AM
#1 - They're for 3rd Gens
#2 - Bad coils aren't bad injectors. They're bad coil packs. Different things.
Sep 10, 2003 | 06:32 AM
No...There is a coil in the injector too. It's not the coil pack.
It's the injector itself...the inductive coil in the injector is an electrical open therefore the coil is shot...
Also a no on the 3rd Gens...There are injectors for 4th gens listed too...
Sep 10, 2003 | 06:39 AM
Quote: No...There is a coil in the injector too. It's not the coil pack.
Sorry, I misunderstood then.
The ECU may be able to handle 5% extra flow. You may be better off buying a used set of stock injectors. I'm sure they can be had for cheep, and you know the ECU can handle them.
Sep 10, 2003 | 09:27 AM
The problems is it already have used injectors...I want a complete new set....
bump for lunch crowd...
Sep 11, 2003 | 09:25 AM
I ordered the Venom Injectors from Summit. UPS to deliver today. Plan to install tonight. Keep your fingers crossed!!! If they don't work, Summit said that I could return them.
Keep you posted!
Sep 22, 2003 | 09:38 AM
I've had the injectors in for about a week now. They dropped right in...no problem with that.
They do seem to flow more, but I'll confirm on my next few tankfuls of gas.
Two other observations...
1. seems to idle a little lower
2. See to be turning lower rpms at high speeds. Before at 70 mph in 5th gear I was at 3k rpm...now I'm at 2.8k rpm at 70...
only thing i can figure is it's due to more fuel per stroke.
So far, i'm happy with the venom injectors. worst part is getting upper intake manifold off.
i haven't g-tech'd it, but it "feels" faster
Sep 22, 2003 | 11:26 AM
lol keep us posted
Sep 22, 2003 | 11:32 AM
Quote: 2. See to be turning lower rpms at high speeds. Before at 70 mph in 5th gear I was at 3k rpm...now I'm at 2.8k rpm at 70...
Glad to hear that they work. However, they won't effect engine RPM at speed. That's a mechanical ration between the engine, tranny and tires. Fuel won't change that.
Oct 10, 2003 | 10:36 AM
Gas mileage has dropped slightly...went from 26ish mpg to 25ish mpg
based on 3 tank fulls....
