Rear License Plate
Old Sep 11, 2003 | 09:24 AM
absurdity's Avatar
Rear License Plate
Hi all, I just bought a '95 Maxima SE. First car, too. What I'm having trouble with is getting the rear license plate off so I can get mine on. Seems to be just a nut and bolt, but getting at the nut behind is quite difficult and I can't quite get at it. Is there any easy way to do this?
Old Sep 11, 2003 | 09:34 AM
mechanicaljoint's Avatar
Sorry, no advise...But welcome to the board. I've also got a '95 SE
Old Sep 11, 2003 | 09:49 AM
clee130's Avatar
It might be rusted together. If that's the case, you might have to drill through or take it to a shop and let them drill it.
Old Sep 11, 2003 | 09:50 AM
chigga's Avatar
welcome both of you!!! i don't think there is a particular way to get it off. just wrestle it off is my guess...
Old Sep 11, 2003 | 10:26 AM
endus's Avatar
An atavistic endeavor...
The frigging thing that the nut screws into starts turning back there and makes it pretty much impossible to get off since there's ****NO**** access to the back of that thing. I have needed to put a new license plate frame on for some time, but have the same problem. I believe the answer is to remove the rear bumper...the plastic part not the substantive part...I am hopeful that this is all that needs to be done.
I am going to try it but I need new plastic clips since they all break whenever you try to remove them.
Old Sep 11, 2003 | 10:29 AM
SuperChris's Avatar
Infiniti 35 Double G's
I had the same problem with my license plate...one of the screws was rusted onto the nut, and that SOB would not budge! After some serious pullin' & tuggin' I ended up ripping out the small piece of plastic (bumper) that held the screw & nut. I had to buy a license plate holder that had 4 screws instead of the usual 2 at the top, just to make sure the darn plate would be secure.
Not the best method, but if the screw won't give, you might have to go caveman style.
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
minsbang
Sep 11, 2015 08:48 PM
flu2000
Sep 8, 2015 02:23 PM
