Removing a Dent
Old 09-11-2003, 07:16 PM
quickie's Avatar
Removing a Dent
Hi, i just got a dent on my drivers side door. Its about the size of a fist, and theres no paint damage. i was wondering if there's a way to remove it without taking it to a body shop? do you think those dent poppers on TV work? Thanks
quickie is offline
Old 09-11-2003, 07:29 PM
ZeRo MaX's Avatar
That's what i wanna know... i have a small dent too... bout the size of a dime... it's sux... everything is nice and shiny.. until i see this dent... anyone know?
ZeRo MaX is offline
Old 09-11-2003, 07:55 PM
onegoode's Avatar
I saw a test demonstration of the suction type dent puller on my local news. They test various products to see if they work.They said that it works
onegoode is offline
Old 09-11-2003, 10:51 PM
mchne's Avatar
Not speaking from personal experience, but from what a friend told me:
Those "as seen on TV" type dent removers (like the "ding king", or whatever) don't work, and can possibly even strip your paint...
If anyone here can personally vouch for these things and prove me wrong, do so by all means please. I have a small dent in my trunk that's just dying for a simple fix.
heh.
mchne is offline
Old 09-12-2003, 06:24 AM
techie's Avatar
As far as the tools, they don't work most of the time. My friend who does paintless removal tried one and said it depends on the dent. It may work for some dents, but not most. If the dent is as big as a fist, most likely even a paintless removal person wont be able to get it to look perfect again. The metal is probably stretched too far. Unless it's not deep, just shallow and wide.
techie is offline
Old 09-12-2003, 11:10 AM
ChristheNite
The best be would be to take the door panel off and get a hand inside there with the windo rolled up and push against the dent from the inside. You should be able to get it.
And for the guy with the dime sized dent - bring it to a body shop and they can probably bondo and paint it for like 100$, if thats too much money you can do it yourself or just live with it.
All those ding doctor and things are ****.
Old 09-12-2003, 12:30 PM
onegoode's Avatar
I just had 2 estimates to fix a dime size paint chip on my hood.They were $367 and $364 to fix it right.A national tire and battery store did it while installing a new battery. The manager isn't wanting to pay for it because he said that he doesn't see how his guy could have done it.If he doesn't agree to pay then i'm going up his corporate ladder and if they still want agree to pay then I'm taking them to small claims court.
onegoode is offline
Old 09-12-2003, 12:54 PM
Respected's Avatar
I haven't done this yet and will try soon, but I have heard that dry ice applied to the metal (not sure exactly how to apply it) will actually pop the dents out. Something about changing the properties of the metal to shrink it.
Anyone else heard of this?
Respected is offline
Old 09-12-2003, 01:58 PM
w30post's Avatar
I have seen the Ding King in action. It has to be original paint. It will remove the large portion of the dent. It will not completely make the dent dissappear. Even on the commercials you can see some distortion left after the tool pops off the car. A body shop owner I know uses one to get the majority of the dent out befor he putties the remainder and paints the car.
Dry Ice does work somethime because it cools a small area and shrinks that areaquickly and thus makes the dent pop out. Usually used on Hail damage..
You may try a local dealer that has a Dent Doctor onsite to remove unsightly dings from your ride. I have seen good results from this.
w30post is offline
Old 09-12-2003, 03:24 PM
polishpunk68's Avatar
where can you get dry ice?
polishpunk68 is offline
Old 09-12-2003, 04:22 PM
I'm nutty for Nissans
JSutter's Avatar
That's a really old trick. I'm sure you have seen Monstor Garage. They heated the roof of a car then cooled it off with a towel drenched in icy water to remove the dent. Well if you saw that episode you would have known this sort of works, it really messed up their roof by making more dents and peaks (for lack of a better word). I wouldn't try this method at home, but maybe the dry ice technique works differently.
JSutter is offline
Old 09-12-2003, 04:44 PM
njmaxseltd's Avatar
Call a Dent Dr. Paintless Dent Removal expert and have them look at your car. If they tell you they can remove it, trust me, it will be 100% perfect when their finished. We use them at the body shop from time to time. The guy who comes by me does excellent work. Even had a ding removed from my front fender, 20 minutes later my car was perfect. They get between $80 - $120 per panel.
njmaxseltd is offline
my03maxima
07-28-2024 07:40 AM
doctorpullit
03-29-2016 11:08 AM
RealityCheck
10-02-2015 06:34 PM
jaydot901
09-29-2015 01:18 PM
Max Nu-BE
09-28-2015 10:25 AM
Quick Reply: Removing a Dent
