99 MAXIMA GLE bumpy auto transmission
Old Sep 18, 2003 | 01:59 PM
ran's Avatar
ran
Hello Everyone. I am very new to this forum. Recently bought 99 Maxima GLE with 97000 km on it. Since first day got a hard 1-2 shift, 2-1 and 1-0 shift and little bumps when I let off the gas at arround 90 km/h. The rest is fine. Is this really a problem, I scheduled appointment with dealership because it is still on warranty. I've seen couple post on that, what is the final word, problem or normal?
Old Sep 18, 2003 | 02:21 PM
2naboy's Avatar
It might be normal depending on how hard the shifts are but first;Try runnig codes and if you have a code that is 12 05( Line Pressure Solenoid Valve (Automatic Transmission)) then do this. Check your transmission resistor. Its located on the side of the driver side strut tower its a grey harness with two wires and it ataches to a thing that's bolted down with two bolts.
Old Sep 25, 2003 | 12:59 PM
ran's Avatar
ran
Hi There
Thanks for reply. There is no codes stored. Dealers looked and found nothing. My main concerne is the situation when I release the gas at 60-80 km/h it shakes the whole car like it goes down to first gear and the same when I aply gas again right after. I will bug the dealer untill they can fix it. By the way, they mentioned something about maintanase records, and if i dont have them they might charge me for tranny repair. I found in the manual that tranny does not need service or oil change up to 96000 km. Any thoghts?
Old Sep 25, 2003 | 07:01 PM
Ninos_Maxima's Avatar
be the change u want2C
Are you sure your in D, and not in 2, or 1?
Old Oct 1, 2003 | 02:18 PM
ran's Avatar
ran
Yes, I am quite shure this is not 1st or 2nd. I can feal the speeds changing.
Old Oct 1, 2003 | 02:27 PM
2naboy's Avatar
you might wanna check your engine mounts, they might be worn and causing excessive engine movements when the tranny shifts. Other than that I wouldn't know anything else to tell you.
Old Oct 1, 2003 | 02:48 PM
ivelweyz
there is no such thing as a 1-0 shift dude...
Old Oct 1, 2003 | 06:16 PM
ran's Avatar
ran
Sorry about 1-0, my mistake. It looks like hard shifting is common problem around maximas auto tranny. I am still concerned aboutthing when I play with gas pedal (press-release quickly) it shakes the whole car sometimes.
Lakersallday24
Nov 7, 2024 07:31 PM
Hawkeye61
Aug 12, 2015 06:45 PM
cmpowell86
Aug 10, 2015 12:35 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
