Best Muffler For 4th Genearation?
Old Sep 18, 2003 | 02:46 PM
SLOW96MAX's Avatar
What does everyone think is the best after market high performance muffler for the 4th generation muffler?
Old Sep 18, 2003 | 02:58 PM
Sqard's Avatar
Catback or muffler?
OBX is an awesome catback, magnaflow is an awesome muffler
Old Sep 19, 2003 | 06:32 AM
SLOW96MAX's Avatar
muffler
Originally Posted by Sqard
Catback or muffler?
Just the muffler. What about bullet?
Old Sep 19, 2003 | 08:41 AM
ivelweyz
High performance muffler is a myth...
Old Sep 19, 2003 | 09:13 AM
Stephen Max's Avatar
True, if you're NA.
Old Sep 19, 2003 | 09:16 AM
WOODYMAX98's Avatar
A muffler is looks and sound. No performance. I have a magnaflow and I love it, sounds great at low rpms and looks even better.
Old Sep 19, 2003 | 09:48 AM
SLOW96MAX's Avatar
muffler
What did you gain in hp or torque from the muffler change?How much does the magnaflow cost?I just don't want it to be loud. I still have the stock exhaust except for y pipe.
Old Sep 19, 2003 | 10:33 AM
infinitiblast's Avatar
I recommend you to go to www.magnaflow.com and listen to the v-6 gti they have in the sounds section. Muffler as far as hp goes...I wouldnt expect more than a couple.
Old Sep 19, 2003 | 11:48 AM
99MAXSE-L's Avatar
so how is the magnaflow sound?? like is it a ricey "bzzzzzzzzzzzzz" or like a deep sound...like "vroommmmmmmm" (bass type, but not loud)
Old Sep 19, 2003 | 12:10 PM
happyricefob's Avatar
V^___^V
http://drewm.dyndns.org/~drew/maxfa...maModifications
Old Sep 19, 2003 | 12:38 PM
99MAXSE-L's Avatar
doesnt work....
Old Sep 19, 2003 | 01:24 PM
Maciek's Avatar
OK, after reading numerous threads and opinions and listening to the sound clips from magnaflow's website I seem to get the drift that magnaflow is the muffler to go with.
But which one?
There is probably a number of mufflers that would fit the 4th gen. But which one to go with?
Which magnaflow muffler do you guys have?
Old Sep 19, 2003 | 01:36 PM
Sqard's Avatar
Mine
http://forums.maxima.org/showthread.php?t=247331
Old Sep 19, 2003 | 01:51 PM
his isnt worth 160 bucks dont go with that. I called magnaflow and they said that the gti exhuast system has a 2.5 inch exhuast and the canistor length of the muffler is 18" versus 14" of the most standard models like the one for sale above. I would look into model 14246 if I was you then get a nice tip welded on. Muffler should be about 85 bucks.
If you only want 2.25 inch inlets and outlets get the 14245. Keep in mind that the longer the canistor length the quieter the sound. Shorter is louder. As noted on magnaflows site it doesnt matter if their canistor is round at 14" or oval at 14" both will sound the same. I recommend getting the 18", I hear 14" sounds nice and deep with some minimal drone..adding that extra 4" of muffler should help clear that up. Up to you though.
Old Sep 19, 2003 | 01:53 PM
SLOW96MAX's Avatar
muffler
I think they are all similar for my application. That is I should see a 10 horsepower increase. I was quoted $175 from a local high performance shop for the magnaflow including welding and tips.
Old Sep 19, 2003 | 01:57 PM
dont count on getting 10hp out of a muffler.
Old Sep 19, 2003 | 02:04 PM
Maciek's Avatar
10 ponies from the muffler alone, no way!
Old Sep 19, 2003 | 02:20 PM
SLOW96MAX's Avatar
muffler
That is what all the dyno tests show. Give or take a few.
Old Sep 19, 2003 | 04:23 PM
speedemn's Avatar
Unless you are running crazy boost... you will not see 10HP from any muffler.
I have heard good things about the sound from a 'Dynomax Super Turbo' muffler. They are not at all expensive either.
Do a search on that as well.
Old Sep 19, 2003 | 04:25 PM
speedemn's Avatar
How long is a stock muffler? Is it 18"?
Old Sep 19, 2003 | 05:32 PM
drewm's Avatar
Originally Posted by 99MAXSE-L
doesnt work....
http://maxmods.dyndns.org/index.php?MaximaPerformance
James92SE
142
Jan 2, 2024 09:23 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
lrb6805
Sep 24, 2015 05:03 PM
TheMafia
Sep 4, 2015 08:26 AM
