Z32 Caliper Conversion: Maxima SS lines or 240sx-300zx SS lines?
Old Sep 20, 2003 | 02:56 PM
teejnut's Avatar
I had a quick question for those with Z32 calipers. Are you guys running Maxima SS lines? or the 240sx to 300zx lines? I've read that stock lines do work but then I also read that we should use the 240sx-300zx lines? Whats the different between the two? Is there a negative of using Maxima lines?
Any input would be appreciated. Thanks!
TJ
Old Sep 20, 2003 | 09:18 PM
Nealoc187's Avatar
SLOW
TJ
Do NOT run maxima lines. Get the 240-300zx conversion lines from www.heavythrottle.com
Old Sep 21, 2003 | 02:54 AM
teejnut's Avatar
Will regular Z32 SS lines work? Or do I have to get the 240-300zx SS conversion lines?
TJ
Old Sep 21, 2003 | 10:46 AM
Nealoc187's Avatar
SLOW
TJ
Z32 lines are a totally different design, they are a hard line. You need the conversion lines.
Old Sep 21, 2003 | 01:24 PM
teejnut's Avatar
hmm ok. where'd you get your lines? i know of pdmracing.com and heavythrottle.com. is there any where else?
Old Sep 21, 2003 | 03:41 PM
image's Avatar
TJ, how much did the upgrade cost you? Whats so good about the upgraded calipers if u dont mind me asking????? Im looking into it, but it looks expensive, kinda makes me wonder if i should be spending that much on break upgrades...
Old Sep 22, 2003 | 01:23 AM
teejnut's Avatar
Umm... calipers depends. Its about $300 for already rebuilt calipers. You can get them pretty cheap (I've heard $100-$200) at your junkyard then do a rebuild. Rebuild kit is ~$60. Conversion SS Lines $100. Rotors and pads depends on what you get but roughly the same price as Maxima rotors and pads.
Without brakes you're car won't stop... I also Auto-x ever so often as well.
Old Sep 22, 2003 | 01:26 AM
teejnut's Avatar
Hey Nealoc187 how much wider are the Z32 calipers? I know they should fit my Kosei's K1 (16") but I'm wondering about my Rota Battle (18")
tcb_02_max
Sep 11, 2015 12:23 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Costa068
Aug 17, 2015 02:13 PM
doobadoo
Aug 15, 2015 06:43 PM
RealityCheck
Aug 5, 2015 06:18 AM
