Help me to check KS diagnose.
Old Sep 20, 2003 | 07:24 PM
ARVY's Avatar
I heard about to use a Ohm gauge to diagnose Knock Sensor by measuring the Ohm between Pin 2 of KS and ground. But now I can not found the post.
I read it was 549KOhm. Is it good or bad?
Thax!!
Old Sep 20, 2003 | 07:44 PM
ivelweyz
even if it's 550k ohms doesn't mean it's OK. I got 550k a couple days ago, checked it and got a KS code on the ECU anyway. If your car lags in the low rpm, below 2500k or so, it most likely needs to be changed...
Old Sep 21, 2003 | 10:32 AM
ARVY's Avatar
Thx buddy! U really gave a clear mind. I will change it next week.
Old Sep 21, 2003 | 12:20 PM
ivelweyz
Before you order a new one try to take off the old one and clean it around the metal to have a better contact area. A little thing like that can make a difference...
maxinout93
Oct 31, 2015 02:04 AM
magiconthetire
Oct 26, 2015 09:03 PM
salty318
Sep 29, 2015 01:21 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
