Does anyones fuel warning light work?
Hey fellas, new Max owner here. I gots me a '96 GXE 5 spd and I cannot get the damned fuel warning ligt to come on! I am a sales rep, and put a shizzz load of miles on my car (most at hwy speeds in fifth), and I have run the car to E on the guage 3 times (450+ miles each time) and I still get no warning light and the tank only takes 15.5 gallons or so. Did Nissan design this car to be impossible to run out of gas? How deep into the 18.5 gallon tank do we have to get to see the light?
you could always pull a Kramer and run it till it stops! that was one of the best sienfeld episodes ever!!!!!
If you search, you will find a post not too long ago where some people responded. The common concensus is, when the light comes on, find a gas station quick. Most people said theirs come on with about 1-2 gallons left in the tank.
Here's the thread:
http://forums.maxima.org/showthread....ght=fuel+light
Here's the thread:
according to my calculations. when the needle hits E. you have 2.5 gallons LEFT in tank. so prolly u would see the light 35 miles ( in street) after u hit E. these are just MY CALCULATIONS. im NOT responsible if u find ur A$$ out of fuel on freeway !
several members ran out of gas almost immediatly after the light came on. so its VERY dangerous
In general, fuel injected vehicles guage reads empty early and the low gas idiot lights come on a gallon or two before the empty point. I've heard that's because if you run out of gas, and the fuel pump continues to cycle on an empty tank, you have a chance of burning out the fuel pump. The fuel running through the pump acts to cool it down under load. My 98 Max idiot light comes on 1-2 gallons before the tank is bone dry. Owners manual says tank capacity is 18.5 gal. I ran my tank dry once (fuel pump survived though) and only managed to put 17.5 gallons back in.
It sounds to me by looking at the "my light does not turn on " may be in 1995's they didn't have one
to do a test when you first turn the key on with in 2seconds all the lights that work should turn on I personally think the 95's don't come with one .......
Oh yeah dealers and any mechanic can say DON'T RUN YOUR CAR BELOW 1/4 OF A TANK...don't ask my fuel pump is not working after I run out of fuel !!!!!!!! he he ...
There is a variable resistor that is in the tank and it has a floating gizmo that works with the fuel gauge. Generally they are the same for all the cars with small differences. I would not try to find out how low can you go because a few reasons: there may be a bad light bulb and if you go too low,you may get all the garbage from the bottom of the tank plus you may find out how your car acts when the tank is dry. I would say that if you are over 400 miles,you should be looking for the pump.
Slamrod
Apr 10, 2016 05:24 PM
follyburr
Aug 12, 2015 10:22 PM
Mine turns on when there is like 1.5 gallons left in the tank.
