Clutch is SQUEALING!!!! Please HELP!!!
Old Feb 13, 2001 | 07:00 PM
swartzzz's Avatar
Lately, I've noticed when I let the clutch out on my max, I've been hearing squealing.. It seems that I might need a new clutch. Has this ever happened to anyone?? What is the best clutch for the money. I have no S/C or NOS. Just the usual mods.... Centerforce? Stillen? Exedy?? Please help. I need directon...
Old Feb 13, 2001 | 07:25 PM
I30CeFiRo's Avatar
Hey same things happening to me! I dunno what it is
Old Feb 13, 2001 | 08:29 PM
dch95's Avatar
Squeel
Lately, I've noticed when I let the clutch out on my max, I've been hearing squealing.. It seems that I might need a new clutchPlease help. I need directon...
If the noise happens after you release the clutch, it,s probably the throw out bearing. This bearing is responsible for pushing against the pressure plate which releases the pressure of the clutch on the flywheel. If you end up replacing it you may as well do you clutch and check to see if the pressure plate and flywheel are okay or if need replacing or resurfacing.
Old Feb 13, 2001 | 10:41 PM
utahmax's Avatar
I had the same problem. So I took my car to the dealer to have it checked out. They said the clutch was fine, and it shouldn't be a problem. It doesn't affect the performance of the car so I can live with it.
Old Feb 14, 2001 | 05:22 AM
Daniel B. Martin's Avatar
Throwout bearing
Originally posted by dch95
If the noise happens after you release the clutch, it,s probably the throw out bearing. ...
I respectfully disagree. If a clutch is adjusted correctly the throwout bearing (a/k/a clutch release bearing) turns at zero rpm after you release the clutch. Therefore it makes no sound after you release the clutch regardless of the bearing's condition. A bad throwout bearing can make a shrill sound when the clutch pedal is pressed (part way or fully).
Old Feb 14, 2001 | 01:29 PM
SleeperSE's Avatar
Re: Throwout bearing
- My clutch has been making a groaning noise for about two months now. It usually starts up once the car has been driven for over ten minutes, but sometimes comes on earlier than that.
- A friend thinks that its just the little starter button at the base of the clutch pedal (the one that prevents starts when the clutch is out). But do you think that it might be my T/O bearing?
- Thanks.
Old Feb 14, 2001 | 03:21 PM
Maxima Clutch Groan
- Thanks.
You are hearing Maxima Clutch Groan. The sound is coming from the clutch itself, not the throwout bearing and certainly not from the "little starter button". It is not a symptom of a defect. Consider it a characteristic of the Maxima.
If the throwout bearing were bad you would hear the squeal with the clutch pedal "floored". If it is Maxima Clutch Groan you will not hear it until the clutch is engaging.
Old Feb 14, 2001 | 05:11 PM
dch95's Avatar
I guess I,m assuming that the noise is being heard while the clutch is being released. Do you think it,s possible though that the bearing would not make the noise while being depressed but could make it during the release? I relealize that after release, there is nothing to cause it to spin but just wondering if the bearing was shot that maybe it might still spin a little. I,m asking because even though I have a 5 speed Celica, I have never heard the noise personally although I did change the bearing out last time I did the clutch (225,000 miles). Just preventive maintenance on my part. TYIA
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
