i need someone to tell me the explicit directions to installing the factory fogs on a
Old Feb 13, 2001 | 07:45 PM
Ryan93SE's Avatar
95-96... do you have to take the bumper off the get the brackets to fit?
Old Feb 14, 2001 | 05:47 AM
mzmtg's Avatar
Minister of Silly Walks
damn people...help a brotha out.
Hehe, just tryin to get Ryan's post back to the top of the page....
Old Feb 14, 2001 | 07:40 AM
Sonic's Avatar
1.)He posted this in the Gen forum too.
2.)Search for it. This has been covered MANY times.
3.)Go to the scanned copy of the instruction manual on Cheston's site. Here you go: http://www.bol.ucla.edu/~cchiu1/fogs.html
Old Feb 14, 2001 | 09:29 AM
Albertt's Avatar
No. If you cut the bumper cover holes properly... >>
you should be able to fit the brackets through.
There's your answer.
Old Feb 14, 2001 | 09:45 AM
Ryan93SE's Avatar
i did search this...
all that i came up with is directions on the 97-99 (which seems alot easier.... im worried about cutting the bumper which i couldnt find anything about.. thats why i posted again about this topic
Old Feb 14, 2001 | 01:29 PM
Sonic's Avatar
Alrighty, here you go:
1.)The fog light kit comes with the two templates to cut out the hole, two pieces of rubber to make the gasket, eight screws to put in the template, the two fog lights, the brackets for them, eight bolts, the relay and the replacement turn signal. Before you do this, make sure that you have the wiring harness for the fog lights. All GLEs and 5speed GXEs come prewired. The auto GXEs that have Cruise Control, intermittent wipers and the power drivers seat have been prewired, the rest of the autos don't (this is from Nissan, not me).
2.)Drill in the template, cut in the spaces that they tell you to in the directions and take out that part. Next put the gasket in the space. Attach the included bracket to the lower part of the bumper with three bolts and attach the actual fog light to the wiring that will be taped up right behind where you are working. Use one bolt to attach the fog light to the bracket and aim. Do this to the other side. Next take the kick panel off from the steering wheel and the collar for the steering wheel off and detach the turn signal(really easy). Attach the new turn signal supplied in the kit and replace the kick panel. Add the relay to the relay box in the engine bay and check to make sure that you have a foglight fuse in the fuse box in the engine bay. After that, turn on the headlights and the foglight switch and they should work.
[Edited by medicsonic on 02-14-2001 at 03:51 PM]
cruce91
Sep 20, 2015 10:23 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
umnitza
Sep 1, 2015 01:03 PM
MikesChevelle
Aug 6, 2015 11:36 AM
