Purge cut soleniod valve
Ok I am getting a check engine light that comes back purge cut soleniod valve. easy enuff right ...WRONG my 95 maxima does not have a purge solenoid attached to the purge box in the rear of the car driver side. I changed the purge box too heavy contaminated light goes off for a week back on same code . Call dealer they have no clue why i have no purge soleniod on the box tell me i have a calif. emmission car and don't know what to do . car runs fine. I have changed all the O2's and purge canister i do not have any electonics going to the box even though the diagram shows it and NO the car was not in an accident or modified I drove it for 2 yrs before this light cam on ANY HELP PLS and no i won't unplug the check engine light. Thanks for any insite.
Hope this helps
You where my only reply the code is P0443. But i am interested in racking your brain alittle. could you scan the page you where teling me about it might prove usefull I read a little more on the snap-on scanner and it mentioned the control valve maybe they are linked together also It is hard to pinpoint the valve you described due to the fact there is multiple wire connections in the intake area and none that fit exactly what you described but a few that where close. I REALLY APPRECIATE all of your help you have been enlighting. What service manual do you have Maybe I'll stop being so cheap and actually get my own copy ..once again thanks a million.
TKHanson
Nov 24, 2018 01:39 AM
magiconthetire
Oct 26, 2015 09:03 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
