Door light not working anymore
Old Sep 28, 2003 | 08:41 PM
Nismo's Avatar
when removing the drivers side door light bulb I accidentaly touched the metal with a screwdriver and the light went out. the bulb is still good but it seems that I shorted something. I looked for a fuse but all I can find was a fuse that said interior lights but that fuse is good. anyone know what the problem is? any particular fuse I should look for?
Old Sep 28, 2003 | 09:29 PM
ny96max's Avatar
get a test light or logic probe and re-check ALL fuses...
Ant
Old Sep 29, 2003 | 12:16 AM
Maxtank's Avatar
I've been trying to find the cure for this for a few months, i did the same thing you did
I"'ve checked everthing, and if you look at the schematic, the door lights and dome are ran on the same fuse/relay, so if one goes out they should all be out. I'm gonne check it out again tomm, but I think there is an inline fuse somewhere
Old Sep 29, 2003 | 12:22 AM
Nismo's Avatar
yea, its weird. all the rest of my lights work fine but that one. I might just take the door panel off and look around for something melted or something
Old Sep 29, 2003 | 02:21 AM
happyricefob's Avatar
V^___^V
yea i have the exact problem for the last 6 months... but i didn't bother to fix it cuz my raybrigs dome is doin a good job so far so yea watever...
Old Sep 29, 2003 | 08:06 AM
BluFlame's Avatar
there is no fuse for door-lights, if you trace the wires they go into window switch. You probably fried something inside. Get a new window switch.
Old Oct 11, 2003 | 09:58 PM
Nismo's Avatar
anyone else know the solution? Just for the heck of it, I took apart my drivers side window switch, took apart the whole thing and I didnt see anything that shows signs of burnt or blown circuit components. not shure what to look for now.
Old Oct 11, 2003 | 10:07 PM
bluA32's Avatar
あおい A32
just get a window switch from a local junkyard n replace it..after that, your light problem will go away. i had the same problem before.
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
