stiff clutch pedal
Old Oct 1, 2003 | 08:34 PM
wrongway15's Avatar
stiff clutch pedal
ok, i just had a new clutch installed and everything seems fine....BUT, after a little driving, the pedal get stiffer...whats up?
please help, i dont wanna screw up this clutch...max has been giving problem after problem.
thanks
Old Oct 1, 2003 | 09:09 PM
99Maxima5sp's Avatar
Ok, well if its new, its pretty normal, at least for my exedy, not 100% sure for OEM (if thats what you have). Mine stopped being stiff after about a coupla hundred miles, now, a coupla thousand later, its as stiff as stock...
Eric
Old Oct 1, 2003 | 09:53 PM
wrongway15's Avatar
yeah its an exedy....but the real reason i was worried was because i had this problem with an exedy (stage 1) then the clutch started slipping like hell after 4-5mos and nissan said something about the pressure plate heating up and causing the slippage, so i got another exedy put in (not by nissan)
i just dont want this problem to happen again. if i blow this clutch i will be ****ed
i dont remember my last exedy pedal being soft then stiff after several shifts....does anyone else experience this?
Old Oct 2, 2003 | 05:28 AM
JAY25's Avatar
instead of replacing it with that POS exedy why didnt you just go with a ACT?
Old Oct 2, 2003 | 06:49 AM
wrongway15's Avatar
because it seems so many people have trouble with ACT and i really dont need an ACT or an EXEDY really....i just wanted something between act and oem and exedy was like $100 more expensive
thanks for that helpful reply
Old Oct 2, 2003 | 12:41 PM
And your reasoning behoind callin a Exedy a POS is what exactly?!
Act and Exedy are of the same quality. the Exedy does have more clamping force as well. And its cheaper. People may be having problems with clutches because of their own doing. Either being installed wrong, defective product or poor breaking in are all factors...
Maybe your arent thinking of a Stage 1 organic kit, because if you are, you have no idea what your talking about
Eric
Old Oct 2, 2003 | 12:55 PM
JAY25's Avatar
Eric
his broke for no apparent reason so what do you call that? POS
Old Oct 2, 2003 | 01:33 PM
Dave B's Avatar
Not DAVEB the parts guy
Eric
ACT uses a Exedy clutch.
As for failures, you forgot to mention that the ACT grabs too hard and ultimately destroys gears. If you run an ACT, granny shift. Anything more and your tranny is a timebomb.
Dave
Old Oct 2, 2003 | 10:30 PM
wrongway15's Avatar
yeah dave b, thats y i didnt buy ACT...multiple posts like yours....and everyone says exedy makes oem...
and exedy was cheaper than oem
Old Oct 3, 2003 | 05:25 AM
nupe500's Avatar
Jedi Knight
the clutch should ease up and get better with driving and wearing in....just be patient and careful with it. good luck
Old Oct 16, 2008 | 07:45 AM
beat_chemist's Avatar
I actually Have the exact same problem...New Clutch soft in the morning and then stiffer as the day goes by, its like so bad that the engagment point changes and at one point the clutch is just slipping as if the clutch was gone..... then i wait for an hour, and its back to soft like butter ?!?!?!?!?! WTF!!!! so now when it gets super stiff to the point of slipping I bleed it and then it works again?!?!?! weird isnt it?
Old Oct 16, 2008 | 09:54 AM
99BlackMaxMS's Avatar
Whats weird is you bumped a 5 year old thread...
Old Oct 16, 2008 | 11:07 AM
QNO_A32's Avatar
awesome first post just awesome
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
