G- Force / Jwt Ecu Avanced Timing
Old Oct 5, 2003 | 10:44 AM
nismos14's Avatar
§è~® f®ÈÄk
Our knock sensor determines some of our ecu's timing advance, if not all of it. now since the ecu's both adjust and advance timing do they by-pass the knock sensor signal?
Old Oct 6, 2003 | 06:52 AM
I30tMikeD's Avatar
No. The knock sensor will adjust timing if pre-ignition occurs. eg; to low of an octane level in the fuel. Advancing the timing will just require you to always use higher octane gas. You won't be able to get by with 89 anymore. So if your running a G-force or JWT ECU it's easier for pre-ignition to occur with lower octane gas.
Old Oct 6, 2003 | 01:54 PM
nismos14's Avatar
§è~® f®ÈÄk
perfect, just what i wanted to know! thanx!
Matt93SE
May 24, 2019 02:58 PM
Slamrod
Sep 3, 2015 07:38 PM
t6378tp
Aug 24, 2015 07:03 AM
3rdmaxse0
Aug 18, 2015 08:25 AM
