My 350Z tires hitting the wheel well... Will Coilovers solve the problem?
Old Oct 6, 2003 | 11:38 AM
maximumpower96's Avatar
Hey People sal here.. my 350Z wheel rims in the back are hitting the edge of the wheel well, I can see if there is a lil bit off height added they wont.. i mean when i am driving alone no problemz it doesnt hit but someone sits in the back and its crazy. So please advise thanx
-Sal
Old Oct 6, 2003 | 11:40 AM
Jeff92se's Avatar
I'm needing a caw
rim or tire? tread or sidewall?
Old Oct 6, 2003 | 11:41 AM
its the tire and its the sidewall that touches when someone is sitting in the rear.
-Sal
ps thanx for the quick reply
Old Oct 6, 2003 | 11:43 AM
Jeff92se's Avatar
I'm needing a caw
frt/rears have the same offset? Wheel/tire sizes?
Old Oct 6, 2003 | 12:45 PM
Uncle Max's Avatar
I thought 350z rears were wider? I have 18x10 with 265 and they don't rub. I would think the front would rub first with the bigger springs? The rear springs are about the same size as coilovers.
How wide are the 350 tires?
Old Oct 6, 2003 | 02:02 PM
nismos14's Avatar
§è~® f®ÈÄk
pics pleaseeeeeee
Old Oct 6, 2003 | 02:15 PM
Uncle Max's Avatar
Originally Posted by nismos14
pics pleaseeeeeee
On the way to a show.
Old Oct 6, 2003 | 02:19 PM
Uncle Max's Avatar
I rolled the fender when I get A LOT of people ( like Chris Tucker says) in my car.
But it doesn't rub against anything on the inside.
Old Oct 6, 2003 | 02:54 PM
ivelweyz
We need a wide body kit so that all this rubbing **** doesn't happen...
Old Oct 6, 2003 | 02:57 PM
Uncle Max's Avatar
proper offset also helps. +35 on my rear wheels
Old Oct 6, 2003 | 08:35 PM
nismos14's Avatar
§è~® f®ÈÄk
beautiful rims
Old Oct 6, 2003 | 08:43 PM
Wisky97SE's Avatar
I spent like 35 seconds looking at that car, I think putting wide wheels in the back (although I would think hurts performance) is what might make the Maxima what it should. It looks like a muscle sedan almost, wow.
[or maybe its because im high)
but yeah, I really like your max.
Old Oct 6, 2003 | 09:22 PM
Black-i30t
well i dont know the thickness of the tires but i will surely put the pictures tommarow and, i cut the inner wheel well inside rather bang it inwards.. but that didnt solve the problem ne way i will try to put up the pictures tommarow...
( its me maximumpower96 using friends computer couldnt find how to logg off sheesh )
-Sal
Old Oct 7, 2003 | 06:23 AM
ohannon7's Avatar
This thread CLICK is goin on now in Tires & Wheels section and 1FSTMAX can probably help you w/ this issue.......
Beautiful set up Uncle!!!!!!!
Old Oct 7, 2003 | 07:04 AM
maxNYC's Avatar
the rims may have a suitable offset but the tiresize is not the same.
The 350Z uses different sized tires than the max. I had the same problem while searching for 2002 maxima wheelsets on sale. I opted to get just the rims alone separately just for fit reasons. If your car is squating a bit in the back, you may need stiffer or higher springs. More things to consider but definitely do the homework before moding your car. Some extra research will save you time, money and aggrevation in the end. good luck
Old Oct 7, 2003 | 07:42 AM
Uncle Max's Avatar
Thanks Guys...
I think the rear tires on the 350 are pretty beefy as well.
Well I hope you get them on there. post some pix. I thought about those wheels for my 240 as well.
I threw my Max wheels on the 240 just to see what it looked like. Man those things fit everything.
Old Oct 7, 2003 | 03:42 PM
97MaxGurl's Avatar
Chick specializing in rounding up 100+ Maximas
Originally Posted by maximumpower96
... when i am driving alone no problemz it doesnt hit but someone sits in the back and its crazy. So please advise thanx -Sal
Maybe your rear struts are shot
AnGe
Old Oct 7, 2003 | 04:11 PM
ange that can be a very good possibility thanx for your advice..
-Sal
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
Ispeedbyu
Wheels/Tires
Aug 21, 2015 02:40 PM
twotonezed
Aug 16, 2015 11:41 AM
