Squeak Squeak goes the Max!
Old Oct 9, 2003 | 02:38 PM
LastBoyScout's Avatar
Well, my max went from squeaking when slowing down to squeaking when i start to at drive and when i turn the wheel (both at very low speeds).
I thought i was just in for new brakes. Now what is the deal?
Old Oct 10, 2003 | 12:10 PM
Bump Bump
Please help me??
Old Oct 10, 2003 | 01:38 PM
silver99
hrmmmm sounds to me like the flux capacitor.
i could be wrong tho, if you were to explain this problem alittle more clearly with more details i would know for sure or not.
Old Oct 10, 2003 | 03:08 PM
MaximaMoJo's Avatar
When this happened squeaking at first when I applied the brakes and then when I drove slowly around corners it was the brake pads that needed to be changed.
Old Oct 13, 2003 | 07:27 AM
I already got one of those from Circuit City. It didnt help any.
I know that i need to replace the brakes. However, now it squeaks when i first start to drive (say 50 feet) and when i turn the wheel at low speeds. I cant explain it any better than to say it is a high pitched squeak, fairly annoying, an sounds to me like in addition to the brakes, i may need to have something else done.
Old Oct 13, 2003 | 12:54 PM
MaximaMoJo's Avatar
That is EXACTLY the same things that were happening when my brakes and only my brakes needed to be replaced. Just replace the brakes and hopefully that will take care of everything.
Old Oct 13, 2003 | 01:33 PM
Thanks MoJo....I will try... Im just afraid that it might be some CV probs, and that has me worried. Hopefully i will get those brakes swapped out fairly soon. Until then squeak squeak.
Old Oct 13, 2003 | 02:18 PM
MaximaMoJo's Avatar
No problem! Good Luck Man!
Old Oct 13, 2003 | 03:40 PM
TofuShop's Avatar
Your problem sounds similar to mine. Even when rolling w/o using the brakes it'll squeak uncontrolably, right? I think your caliper is sticky or stuck. I looked thru my Hanes and i oiled that sucker up a bit a month or two ago. Been fine ever since.
Old Oct 13, 2003 | 03:43 PM
MadChef's Avatar
Just a thought, but I recently had a strange squeaking sound when coming to a quick stop, or on rough terrain.
Turned out that one of my muffler clamps was "dead", so what I was hearing was the broken one scraping against other metal under my car.
Got a new ones in there, no "squeaks" =)
Old Oct 13, 2003 | 04:04 PM
NissanMasterTec's Avatar
you need to replace the brake pads, the squeal tabs are touching the rotors.
Old Oct 14, 2003 | 01:54 PM
CKOTuHA's Avatar
I had the same annoying sound. Changed my brakepads and rotors since they were warped, and everything went away
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
