need help with brakes
Old Oct 9, 2003 | 07:28 PM
JeEvE's Avatar
Hey, the brakes on my max dont work too great. I think they should be better, and under heavy breaking it gets a little ruff. Anyone know what it can be? I bought the max a few weeks ago, the lady told me she jus got the new pads and rotors. First I think I should get some good pads but Im not sure which ones I should get with these rotors. What should I go with? I do normal driving and sometimes heavy breaking.
Old Oct 9, 2003 | 11:44 PM
Chunger's Avatar
My other car is a Hybrid
"ruff" doesn't really describe much nor give people something to work with...
Check the sticky posts above for help, too.
Old Oct 10, 2003 | 03:09 AM
spiff56747's Avatar
if you just got new pads and rotors, there isnt much to do except bleed the brakes.. unless something is not installed properly
Old Oct 10, 2003 | 11:10 AM
Brudaddy's Avatar
Unless you do any amount of seriously hard breaking, there is no need to upgrade to better rotors or pads. Just save your money. And I have tried to use a couple of different performance pads because they were supposed to be a harder compound and less dust when using in town...they aren't. They are just a waste of money. Napa pads stop just a quickly and these "high grade" pads I have put out just as much dust as any normal pads. I think that there is just no way around some break dust, no matter what some people tell you.
Old Oct 13, 2003 | 11:34 PM
DoGGy
ceramic brakes is the way to go
Old Oct 13, 2003 | 11:47 PM
joaquink's Avatar
¿Hablas Español?
Jeezus, what's happened to my beloved 4th-Gen forum?
What does ruff mean? Is that anything like rough? Do you mean that you feel a lot of vibration when braking hard? Do you have ABS? Are your tires inflated properly? Did you get the rotors turned? Have you bled the brakes (notice - brakes, not breaks and braking, not breaking)? What pads and rotors are currently installed? Do you have grooves that are noticed by a swipe of your finger across the rotor? What pads are in there? Are they evenly worn?
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
