I changed my capilers and brake lines and my brakes are still messed up!!!need help!!
Old Oct 13, 2003 | 08:06 PM
99maxx-on19's's Avatar
yeah now my car is jacked up in the garage i tried to bleed them but the fluid only comes out in the left front and none in the right front.I changed calipers and brake lines on both sides but the front right pads get tight. I put it in gear and only the left side spins but i step on the brake and it keeps going???but the right side never moves??I'm so confused can anyone please help out
Old Oct 13, 2003 | 09:54 PM
SXN's Avatar
SXN
first suggestion is check all your lines and hoses. also, does your brake system have enough fluid?
Old Oct 13, 2003 | 10:46 PM
ivelweyz
You need to bleed the rears first, see if that helps...
Old Oct 13, 2003 | 11:58 PM
joaquink's Avatar
¿Hablas Español?
Have you checked for binding or kinks in your brake lines? Have you rechecked your fittings to make sure your brake lines are seated properly? Did you rebuild your wheel cylinders?
wyobbagy
Jan 3, 2023 12:03 PM
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
