HELP Max through 3 maybe 4 alternators in 1 year?!?
Old Oct 11, 2003 | 10:58 AM
95MAXIMASExy's Avatar
i have a 96 maxima se auto that is now on it 4TH! alternator in less than one year. Now it is showing the same symptoms of another one except no battery+brake light indicators, which signify alternator troubles. What could be wrong with the car? My shop did voltage tests on all of the wiring in the car and the battery is less than a year old and has tested ok at 2 different places. Are alternators jsut made this poorly? I really need help this is getting really old, does anyone have any suggestions?
PLEASE HELP
Old Oct 11, 2003 | 11:01 AM
Kevlo911's Avatar
Kevlo for President
is there a short anywhere? what amp fuse are u using? where have u been getting hte alternators from?
Old Oct 11, 2003 | 01:52 PM
no shorts were found when the shop looked for them, im not sure what kind of alternator is used though, does the make of alternator really matter?
Old Oct 11, 2003 | 01:58 PM
ivelweyz
Onw would think that after 2 alternators going out on you you'd realize that it's not the problem and you'd try to figure out what is. Sorry I can't really help you but you might want to check for other symptoms before you waste more money on alternators...
Old Oct 11, 2003 | 02:11 PM
TheNip73's Avatar
I bet you have a high current audio system... does it every time.
Old Oct 11, 2003 | 02:17 PM
Kevlo911's Avatar
Kevlo for President
yes it does matter, where did the alternator come from?
would u want a fram filter in ur car or a high quality nissan one?
Old Oct 11, 2003 | 02:21 PM
TheNip73's Avatar
You really need to edit this post and indicate you are replying to a quote... I had no idea what you were saying until I reread the entire post.
You were answering the folliowing question :
Old Oct 11, 2003 | 03:50 PM
worm's Avatar
I think that I've posted this before but i never got a reply. My alternator in my 98 was recalled, dont know if that has anything to do with it.
Sorry, just looked at your post and relized you have a 95, might want to look into that though.
Old Oct 11, 2003 | 05:13 PM
one was purchased with a lifetime warrenty from autozone, the others were done professionaly with a year warranty on parts and labor (thank goodness). So should I get ripped off from the nissan dealership and buy one from them?
Old Oct 11, 2003 | 05:17 PM
by the way i actually have the a stock bose system in the car and the car is completely stock other than fluids, battery, alternator.
Old Oct 11, 2003 | 05:21 PM
Kevlo911's Avatar
Kevlo for President
what has been wrong with them? have they been shrting or bearing going bad?
Old Oct 11, 2003 | 06:34 PM
the problem with the alternators is that they only put out about 12 amps when they are tested not the needed 60? or so ( im not sure about the normal amperage).
Old Oct 11, 2003 | 06:39 PM
Kevlo911's Avatar
Kevlo for President
normal i believe is 60-80amps at idle
i think there is a short somewhere, have u tried to follow the wires? if so did u find anything odd? how bout the connector, is it in all the way? mine was not and i had to push the wires into the harness more so it made conect with alternator
Old Oct 11, 2003 | 07:03 PM
the weird thing is that when the alternator is replaced its amperage is in the correct range when they test it. After about a month or two it trips the alternator trouble code and only puts out amps in the 10-20 range.
Old Oct 11, 2003 | 07:22 PM
NissanMasterTec's Avatar
I suggest that you stop buying cheap aftermarket rebuilt alternators from Pep-Boys or NAPA.
Spend the money and go to the dealership and get a factory OEM replacement alternator
Old Oct 11, 2003 | 07:54 PM
97GLES's Avatar
i have to agree, go get a nissan alternator.
i picked up a 125amp alt from nissan. i paid $303
Old Oct 12, 2003 | 06:04 AM
Kevlo911's Avatar
Kevlo for President
http://www.trademotion.com/partlocat...=1&catalogid=1
274$ OEM nissan
Matt93SE
May 24, 2019 02:58 PM
PH98I30
19
Jun 13, 2016 02:38 PM
Balkins
Feb 1, 2016 12:45 AM
homeyclaus
Sep 3, 2015 06:15 PM
JMag90
Aug 25, 2015 09:17 AM
