Fuel Pump Wire Color for kill switch.
Old Oct 12, 2003 | 01:21 PM
meanbean's Avatar
I am trying to install a kill switch and cannot determine what color and plug the fuel pump wire is behind the driver side fuse box. I have a Hayes manual but cannot seem to find any mention of the color of the wire behind the fuse box. Can someone who has done this mod give me some assistance? Thanks for the help.
Old Oct 12, 2003 | 03:51 PM
nupe500's Avatar
Jedi Knight
green with orange stripe
Old Oct 12, 2003 | 06:37 PM
Krash513's Avatar
I tried to do the very same thing, im not sure what wire i cut, but i checked and double checked the manual.... ended up cutting the power seat wire and spent 2 hrs fixing it.... im curious if thats the right wire.. let us know
Old Oct 15, 2003 | 10:59 PM
meanbean's Avatar
Nupe5000....green/orange is the wrong wire color. There are 2 wires with that color scheme behind the fuse box and neither of them are correct wire to disable the fuel pump. I found out the hard way by cutting them both and then wasted half an hour repairing the mistake. After some further research, I determined that the correct wire to cut is the Black/white wire on the connector block directly behind the relays. Krash513....there is only 1 black/white wire behind the fuse box so there should be no confusion this time. I got my kill switch working now so PM me if you need some help.
The Frye
Sep 2, 2021 11:03 AM
BkGreen97
Apr 2, 2016 05:47 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
