how hard is it taking the intake manifold off to deal with the knock sensor easily?
Old Oct 12, 2003 | 06:36 PM
balla95_se's Avatar
has anyone ever done it? I don't know why, but my knock sensor is pretty dead in the middle of the thing. I can barely see it with a flashlight! Anyone done it before?
Old Oct 12, 2003 | 07:07 PM
nismos14's Avatar
§è~® f®ÈÄk
lots ppl have done it, easy, just time consuming
Old Oct 12, 2003 | 07:08 PM
mzmtg's Avatar
Minister of Silly Walks
It is much, much more hassle to take the manifolds and injectors off than it is to just reach in from the side.
It takes about 20 minutes tops if you go in from the side. It will take you about 3 hours, minimum, to get the manifolds on and off.
Old Oct 12, 2003 | 07:46 PM
KWheelzSB's Avatar
Ditto this. You'll just need a ratchet, a universal joint adapter & a 1' socket extension plus the appropriate size (forgot) socket.
With a little elbow grease, you'll have it out in no time flat.
Old Oct 12, 2003 | 08:17 PM
sweetdaddy's Avatar
True dat. Get a 1/4" drive socket (12mm) with universal joint built in and the 1/4" drive extension 12-14" long. The socket with joint built in is shorter than a u joint mated to a socket and avoids clearance/angle issues. The narrower diam 1/4" drive extension (vs 3/8") gives you a better angle on the bolt as well. Get a magnetic tipped retrieval tool for when you drop the bolt and a claw tool with flexible shaft to hold ks for easier reinstallation.
Old Oct 12, 2003 | 08:23 PM
96shogunmax's Avatar
I did mine in about 5 -10 minutes but i dont have a fat hand
Old Oct 12, 2003 | 08:49 PM
1996blackmax's Avatar
No need to take the manifold off. I used the instructions from here:
http://www.skippynet.com/maxima/knocksensor.htm
They came in very handy. My 9 year old son helped me put in the new KS. He has thin arms and got the thread started, I just covered all the sharp edges with rags so he would not get any cuts. Car felt great afterwards .
vingodine
45
May 21, 2016 12:46 PM
iflexsteel
Sep 15, 2015 03:37 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaxStock
Aug 12, 2015 08:33 AM
