A question about ATF flush/refill???????
Old Oct 14, 2003 | 01:10 PM
Lloyds96Max's Avatar
I figured there was a good reason why no one has suggested or done it yet but I will ask this question anyway: Can I flush the old transmission fluid with an ATF that is a less expensive substitute then refill it with Amsoil ATF? Is this method problematic? Thanks for any replies and insight from the org.
Old Oct 14, 2003 | 02:31 PM
Jatan's Avatar
Use the search...
Go here: http://forums.maxima.org/forumdisplay.php?f=70 and go to the Sticky about the ATF...
Old Oct 16, 2003 | 08:40 PM
Thanks for the thread it was helpful...Can anyone answer my question on using a less expensive synthetic ATF just to flush my old transmission fluid? has anyone done this before whileperforming a flush of the old fluid? I intend to use Amsoil but want to save a few dollars if possible.
Old Oct 17, 2003 | 12:35 AM
Ninos_Maxima's Avatar
be the change u want2C
Doesnt every one do this? I remember reading a lot of threads like this one. Isisnt it also good to just keep a little of the old Tranny oil still in to help break in the new oil or something like that?
Old Oct 17, 2003 | 05:41 AM
big_al's Avatar
Sounds alright, just think it thru
Old Oct 17, 2003 | 02:12 PM
jbreit's Avatar
when flushing, there is little actual mixing of the new and old...you only "waste" around 2 quarts so figure you could save $8 if you cheap out on it....which is only a fraction of what you are already saving by doing it yourself. Though, admittedly I have used a name brand like Valvoline to use as the first 6 quarts, then used Mobil ATF for the last 6....I did this same thing on my MAX and that was 15,000 miles ago and still runs like a top (115K on the clock now). The tranny did feel much better after this.
good luck.
JB
Old Oct 17, 2003 | 02:14 PM
jbreit's Avatar
when flushing, there is little actual mixing of the new and old...you only "waste" around 2-3 quarts. Though, admittedly I have used a name brand like Valvoline to use as the first 6 quarts, then used Mobil ATF for the last 6....I did this same thing on my MAX and that was 15,000 miles ago and still runs like a top (115K on the clock now). The tranny did feel much better after this.
good luck.
JB
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
