what's the difference between 95-96 and 97-99
Old Oct 15, 2003 | 01:53 PM
Chris96SE's Avatar
There's 190hp on 95-96 stock, and 222hp on 97-99... why is this? is it the same engine, and just a few things have been changed? can I do minor changes to my 96 to get my hp up to a 97-99??
Old Oct 15, 2003 | 01:54 PM
MrEous's Avatar
^ Jeff™
95-99 are rated the same hp from the crank...no matter what.
190hp for everyone.
Old Oct 15, 2003 | 02:06 PM
NookieMax's Avatar
the 222hp didn't come till 2000 model year. Its the same engine block but with changes to the intake runners, exhaust and ECU characteristics, thats as far as i know. Plus the 2000s have the whole restyle thing.
Old Oct 15, 2003 | 02:08 PM
daroknessmonsto
190hp for everyone.
1234567
Old Oct 15, 2003 | 02:41 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Mechanically, nothing has changed from '95-'99, a few notable changes for '99 such as emissions equipment and TCS
Cosmetic wise, this is all in the FAQs
Old Oct 15, 2003 | 05:21 PM
ivelweyz
why wasn't this thread closed seconds after it was posted???
Old Oct 15, 2003 | 06:01 PM
KsuMax's Avatar
Cheesing away...
Don't know, but it's still open. Chris96SE - Who told you it had 222hp.
Old Oct 15, 2003 | 07:56 PM
Mmmaxx's Avatar
this brings up and interesting point, although I know that they are all the same (4thgen) hp wise. I did see alot of websites saying it was 220hp at the crank for 99 models while doing research before i purchased my 99se
Old Oct 15, 2003 | 11:09 PM
Chris96SE's Avatar
ivelweyz, well sorrrry I'm not as knowledgeable as you are with maximas.. keep it to yourself, I don't wanna hear your complaints, I don't think anyone else does either...
Thanks everyone else for your explanations..
hopefully someone has a foresure answer, cause I'm very curious
Old Oct 15, 2003 | 11:17 PM
mchne's Avatar
I never thought I'd stoop to this level, but...
read the FAQ's ffs. =p
Old Oct 16, 2003 | 04:40 AM
Albertt's Avatar
To get your car to ~220bhp, you'll need to do serious changes.
Old Oct 16, 2003 | 05:02 AM
dave harms's Avatar
99 had two distinct models
late 99's had a preview for the 2k.
i can't recall exactly what the HP is, but it's up with the 2K.
other than that, all 4th gens were created equal (generally speaking)
i think the 99ES is the unique model......... not SE
Old Oct 16, 2003 | 06:22 AM
nupe500's Avatar
Jedi Knight
Dave,
I don't believe there was a 99ES model. In fact I'm pretty sure that there isn't one...maybe you're referring to the SE-L model which is slightly different from the regular SE. All 4th gens are supposed to be created the same, but like others have mentioned there are some cosmetic differences as well as mechanical ones with relation to where the EVAC cannister is located, and wiring harnesses are different
Old Oct 16, 2003 | 07:04 AM
MaximaEvolution's Avatar
one difference is that you can easily get a pair of red clears for a 97-99. Forget tryin to find em for a 95-96!
Old Oct 16, 2003 | 07:34 AM
maxNYC's Avatar
ODBI versus ODBII. Computers are different between the 95-96 and 97-99 models. 99.5 models use different ECU's and cannot be chipped.
Old Oct 16, 2003 | 09:29 AM
Brudaddy's Avatar
horsepwr
There is no horsepower difference, to the best of my knowledge, in any of the 4th generation maximas. It is rated at 190. However, it will pull hard, if you have a 5spd, on the more powerful 222hp 2000. My friend has a 2000, and mine is quicker @ 100% stock than his. His was auto and mine is stick. Prob. just cause mine weighs less.
Cosmetically, the taillights are swapped from 95-97 to 98-99. On the older ones, the actual taillights are on the bottom of the two rows. The turn signals are on the top. On the 98-99, the taillights are on top. Also, there is a little difference in trunk lid. On the older ones, it comes in toward the car a little, and on the newer ones...there is a little air foil that sticks out ever so slightly. Those are the most glaring differences besides wheels, of course.
I have heard there are chips available for 99.5. Are there not? I know that we have a different ECU, but I thought it was still able to be modified with a chip.
Old Oct 16, 2003 | 09:33 AM
TheMax95's Avatar
ODBI versus ODBII. <A TITLE="Click for more information about computers" STYLE="background-color: #f0f000; " HREF="http://search.targetwords.com/u.search?x=5977|1||||computers|AA1VDw">Computers</A> are different between the 95-96 and 97-99 models. 99.5 models use different ECU's and cannot be chipped.
exactly.
changes from the ext: grille, wheels/tires, trunklid and taillights, headlight housing, foglights, front bumper.....I'm probably forgeting some
-Paul
Old Oct 16, 2003 | 10:53 AM
Maxima99SE's Avatar
will fly for food
Originally Posted by TheMax95
exactly.
-Paul
back bumper, steering wheel, the way the fuel gauge faces (it's pointing outward on 95-97, and pointing towards the middle on 98-99s), buttons on the steering wheels of 95-96 are bigger than 97-99
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
Calabar
Oct 5, 2015 09:57 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
