Is there any tricks to replace belts (not timing)
Originally Posted by rushnboy
Is there any tricks to replace belts (not timing) on Maxima '99
Thanks.
Thanks.
He said not the timing belt, which for that matter we don't even have.
The blets are pretty straight forward, no real "tricks" involved. Pickup a Haynes manual...their writeup is pretty good.
we don't have a timing belt we have a chain that doesn't have to be replaced. As far as replacing your belts there is not really a trick to it you just have to loosen up the tensioner and the belts will come right off. Make sure you have a diagram of how the new belts are going to be installed.
The only trick would to be to avoid belt tension that's too high or too low. And you really gotta go out of your way to fukk it up. Too low and the belt slips,too high the belt can wear prematurely or stress the bearings of the tensioner & components. I just count the turns when I loosen the tensioner, return it to roughly the same point using a stock Nissan replacement belt.
Hondarydr
Dec 30, 2024 06:15 PM
kenc15
Sep 25, 2015 06:38 AM
JMag90
Aug 25, 2015 09:17 AM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
