Driver Window Doesn't Go All the way down
Old Oct 16, 2003 | 09:05 AM
WaarrEagle's Avatar
As of this morning my driver window does not go down all the way. It looks like its working fine until it gets about an inch from the bottom. Then the rear half of the window stops and the front half moves down a bit rotating the window until it wedges itself to a stop. Is this something I can fix and if so how? Thanks!
Old Oct 16, 2003 | 09:23 AM
JeffesonM's Avatar
living out of a maxima...
Mine does this too every once in a while, but I haven't figured out why yet. It usually rights itself in a day or two.
Old Oct 16, 2003 | 10:20 AM
kenji's Avatar
Take apart your door and check for obstacles.. Most likely a piece of styrofoam inside your door came loose and is blocking the window's path (this happened to me after I got a dent popped in my door)
Old Oct 16, 2003 | 10:22 AM
mchne's Avatar
this definintely makes it sound like there's something stuck down there.
Old Oct 16, 2003 | 11:49 AM
wariow's Avatar
don't force it to go down or you might break the track or rip the glue off the window. Open it up and see what's up with it.
Old Oct 16, 2003 | 01:26 PM
WaarrEagle's Avatar
I finally got a chance to open it up this afternoon and sure enough the piece of styrofoam that was glued on the door panel fell off and was wedged down there. It was a very easy fix and now everything works great. Thanks for the help everyone.
Mar 12, 2020 12:06 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
boomerbrian
Sep 2, 2015 03:46 PM
