Starter Removal
Old Oct 18, 2003 | 01:20 PM
T-One's Avatar
Starter Removal
I performed a "starter removal" search. It seems quite easy. However, how do you unplug that small black wire? It's soldered to the starter solenoid on one end. I can't figure out how to unplug the other end.
Thanks,
Old Oct 18, 2003 | 01:21 PM
Conrad283's Avatar
I need a truck
i'm pretty sure it's attached by a screw .. check it out
Old Oct 18, 2003 | 01:26 PM
T-One's Avatar
Just checked it. It's soldered to the solendoid. The other end goes into a plastic gray clip/housing. Can't figure out how to unplug it from the plastic housing.
Old Oct 18, 2003 | 06:09 PM
maxpol's Avatar
The connector unclips in the middle of the grey connection.This connector is clipped into a piece of metal.It is tough to get to without removing the white plastic piece under the connector.Play around with it and you should get it.
Old Oct 18, 2003 | 06:14 PM
Jatan's Avatar
Removing: http://www.motorvate.ca/mvp.php/516
Old Oct 18, 2003 | 10:42 PM
NissanSE98's Avatar
Just wondering why you are trying to remove your starter-- i removed mine a few weeks ago because it wasn't disengaging fast enough from the fly wheel. I lubed it up but it still does it on occasion.
Old Oct 19, 2003 | 06:16 AM
Jatan's Avatar
Maybe he's replacing it...
Old Oct 19, 2003 | 04:00 PM
NissanSE98's Avatar
well.. maybe you're a deuce bag
Old Oct 19, 2003 | 05:03 PM
T-One's Avatar
I lubed the gears. After engaging, the starter would make a strange noise. Looking in MotorVate.com, I found my starter problem. After lubing, no more noise.
Old Oct 19, 2003 | 05:05 PM
T-One's Avatar
I didn't want to break anything, so I removed the metal mounting bracket. I then figured out how to disconnect the darn thing. Thanks for the tip.
Old Oct 19, 2003 | 07:26 PM
Jatan's Avatar
Old Oct 20, 2003 | 12:55 AM
rguida's Avatar
someone just got pwned
Old Oct 20, 2003 | 03:27 PM
NissanSE98's Avatar
ha ha...shut up
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
maxima297
Sep 30, 2015 03:32 PM
jaydot901
Sep 29, 2015 01:18 PM
