Question About Studs??
Old Oct 19, 2003 | 02:32 PM
97BLUEMAX's Avatar
What Is The Best Way To Install New Rear Studs Your Self??????????
Old Oct 19, 2003 | 02:36 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
take wheel off
unbolt brakes
pull off rotor
hammer out old stud
either use a presser or while holding the stud in place, put the rotor back in place, and tighten a lugnut back on
reinstall everything else
Old Oct 19, 2003 | 06:37 PM
97BLUEMAX's Avatar
i did that but i didn't put the rotor on and i had them most the way in and then turn the lug again and the stud came loose or something and as i turned the lug the stud turned two so i had to cut the stud off.
Old Oct 19, 2003 | 09:18 PM
97BLUEMAX's Avatar
Anyone??????????????????
Old Oct 19, 2003 | 10:11 PM
KWheelzSB's Avatar
You have to remove the hub assembly (part with the studs in it) from the car to do this install properly.
Pound out the old studs with a hammer and a punch (don't hit the ends of the old studs directly with a hammer, as you can damage the first threads, making them unusable)
With the hub assembly secure in a vise, insert the new stud and using a socket as a spacer, along with a large washer, thread one of the lug nuts onto the new stud & using a socket & torque wrench, draw the stud securely into the hub assembly until it is completely seated in the hole.
It should take approximately 120 ft/lbs to draw the stud all the way in.
I suspect the problem you encountered was a result of the stud not having been securely seated in place - this would explain why it spun in the hub assembly.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
