check engine light, me too (diff problem)
Check the code from the ECU that will tell you your problem. Going to the dealership will be even easier. they just hook up the diagnostic computer where the fueses are and it tells you.
Originally posted by BlancMax
95 SE
had problem starting 3 or 4 times over a week, does anybody have a clue???
95 SE
> ... had problem starting 3 or 4 times ...
It is helpful to give as much detail as possible. When you say "problem starting", do you mean that the engine did not crank (Rrrr-Rrrr-Rrrr)? Did you mean it cranked but did not fire (Vrooom!)? Was the problem associated with a cold engine, warm engine, or both? When the engine finally did start, did it run smoothly and with normal power?
maxinout93
Aug 20, 2015 02:17 AM
bassmann
Aug 3, 2015 07:53 PM
