homelink visor?
Originally Posted by techie
well i tried searching i swear. i guess im just lazy.
Originally Posted by mendon11
awesome...thanks
also, can i just press any of the buttons on the homelink
u can program any of the buttons, but they will each activate a different garage if u want, or u can have all three activate the same one, why you would do that, i have no clue but yeah.....
Originally Posted by nismos14
yes it gets power from the wiring harness thats connected to the light in the mirror, u can hook it up just like ur stock one was hooked up, should work no problem my bro did it
speaking of this....how do you program the visor to open your garage door?
Just one thing to add to Nismo14 reply. Depending on the opener you have you may have to do an additional step. Program the visor as the owners manual and Nismo said. If it's not working after that, you have an opener with a rolling code that is required to learn new remotes. If this is the case, you should have a button on the garage door opener, probably near the sensitivity settings, that you have to push to put into learn mode, then hit the button on the homelink visor that you programmed. This is what I had to do to get mine to work
that makes sense, my garage door opener is like 14 yrs old, needless to say it doesnt use rolling codes
seems to me u'd have to run a positive n negative wire, and get a harness to attach to the visor to power it up
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
ef9
Sep 5, 2015 11:18 PM
