Help w/Fogs on Sarona body kit!
Old Oct 29, 2003 | 04:22 PM
95MaximaPimp's Avatar
I just had the Sarona body kit installed on my '95. The factory fog lights don't fit right. Has anybody done the modification to get them to fit? I could use the help. Thanks.
Old Oct 29, 2003 | 06:14 PM
ivelweyz
Who told you they're supposed to fit? As far as I know there is not kit that incorporates stock fogs into it. Some if not most have holes for the clear corners but for fogs it's custom work. Not really worth it...
Old Oct 29, 2003 | 07:21 PM
Anyone know what aftermarket fogs will fit?
Old Oct 29, 2003 | 07:33 PM
99Maxima5sp's Avatar
I think its designed for 97-up fogs...
Eric
Old Oct 29, 2003 | 09:05 PM
ivelweyz
nope, look at their site...
Old Oct 29, 2003 | 09:46 PM
Well if its this kit by sarona... (BTW, i got this from their site )
Then it certainly looks like it was designed for 97-up fogs. If its the newer sarona, then no...
Eric
Old Oct 29, 2003 | 09:48 PM
ivelweyz
he doesn't have a 97+ though, I see what you mean however...
Old Oct 30, 2003 | 07:28 AM
LastBoyScout's Avatar
Since you can fit the same front and rear on the 95-99 they just designed one setup. It should take the 97-99 fogs. I personally like the 95-96 fogs better. You could do it, and that would make your car a little more unique.
Old Oct 30, 2003 | 10:35 AM
ny96max's Avatar
ok, let me clarify a few things. The Sarona body kit is degined based off the 97-99 front end, thats why you need to buy a 97-99 grill if you own a 95-96 max. The factory fogs for the 97-99 are the ONLY fogs that will fit with the Sarona kit, thats just common sense.
...i think next time before you go and buy something you should do a lil investigating and make sure what your buying will work for your car.
Ant
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
