failed 5spd tranny... advise needed.
Old Oct 30, 2003 | 12:13 PM
JMAXIMA's Avatar
i have a noise that continues to get louder as the week goes on... went to a trans. shop today and they were not 100% sure, but they seemed to think it was an input shaft bearing failing. so, the owner said that 90% of the time i can replace a manual trans. for the price of repairs... so fixing it may not be worth it. so i started looking around and i found a 5spd from a 98' w/ 65k on it... for $500 w/ a 9mo. parts warranty. worth it or not? or should i get a second shop to look at it. i just don't have much $$ to blow and $500 seems like a deal for me... and since i can install this in an evening, the $500 is all i will pay.
-jon
Old Oct 30, 2003 | 12:37 PM
xsnowpig's Avatar
-jon
I just spent $1024 on a rebuild that i already pulled from the car myself. the cheapest used 5sp i found around denver was still around $1000.
Old Oct 30, 2003 | 01:17 PM
nupe500's Avatar
Jedi Knight
I would buy the cheap one and put that in, but keep in mind that you might encounter the same problem again soon.
Old Oct 30, 2003 | 01:29 PM
matty's Avatar
Imput shaft bearing will make a noise when the Clutch is released...Neutral take your foot off the clutch and listen to a noise in the tranny....and noise during the movement of the car is a differnt bearing....Wait for the tranny to blow, may never, then do it
-matt
Old Oct 30, 2003 | 01:31 PM
JMAXIMA's Avatar
yeah, but i only plan to keep this car for 1 more year at most. but thanks for the heads up.
Old Oct 30, 2003 | 01:44 PM
Ramius83
Eh, if you are keeping it that long than just buy that '98 tranny and slap it in. If you were keeping it longer I would say to shim the diff bearings and replace them.
Old Oct 31, 2003 | 05:46 AM
luckee2bhere's Avatar
i have been looking around too.
$500 is the best you will find....get it.
somehow i found a '00 trans with 33k miles on it for $500...but i doubt that find is often.
Old Nov 1, 2003 | 05:35 AM
JMAXIMA's Avatar
yeah, it will be delivered to my work on monday... but i'm guessing by the end of this month the car will be gone. i just have a feeling that this car is going to turn into a headache... so its time to get rid of the Max... maybe a 2003 6spd will be in my future...
Old Nov 1, 2003 | 12:36 PM
mrnock's Avatar
where would you go to look for 5spd trannys anyway?
Old Nov 2, 2003 | 04:16 PM
JMAXIMA's Avatar
car-parts.com
Old Nov 2, 2003 | 04:19 PM
Capital15's Avatar
Blown transmissions give me chills. Bad memories.
litch
123
Jan 4, 2024 07:01 PM
ef9
Oct 4, 2015 08:43 AM
Noela
Sep 26, 2015 08:22 AM
