Courtesy MEVI question
pretty shure you need harlan, dawes/GM, vac can, all wires, hoses, and everything electrical/vacuum related, ect..
I think they only sell you the manifold, cover, butterfly with hardware, actuator and gasket.
Originally Posted by iansw
That's the funny thing.
I've sold Harlans with my kits and not one of the people I've sold to has had problems.
Only the ones Cranman sold.
bad batch maybe?
bad batch maybe?
Also, my MEVI from courtesy came with the decorative cover.
MAKE SURE YOU USE RED LOCTITE ON BUTTERFLY valves. I should be done with my engine rebuild by thanksgiving. Only took me six months
Originally Posted by SLC98Max
iansw, do you sell a relay with your kits as well? Cranman's kits didn't have a relay and I think this caused to much current to be drawn through the harlan. Of course if your kit doesn't have a relay than that doesn't explain it.
Anyway - yeah - I always send a relay with my kit. Whether or not someone uses it is up to them.
My harlan got fried, but that "may" have been my fault. I was using a relay and I had a led inside the car to light up when it was activated. I ordered the summit one, should be here in a couple of days.
bad batch maybe?
bad batch maybe?
Regarding Courtesy, you can get every mechanical part except the electrical/vacuum stuff (Rpm Switch,Solenoid, lines, etc.). You could buy parts off a 3rd gen VE, but it's very expensive.
-hype
litch
123
01-04-2024 07:01 PM
Unclejunebug
04-02-2016 05:42 AM
