Cattman Headers Installed
Old Nov 3, 2003 | 11:30 PM
Iron Lung's Avatar
My intention this weekend was to install both the headers and the cams. Myself and Y2KSESteve didn't get started until late Sunday, so I decided to just go with the headers right now. It will also give me the chance to dyno with the headers only.
First off installation. Not really to bad, but time consuming. I started with soaking all of the exhaust bolts with WD-40 while it was still hot.
The process went something like this:
*Removed Y-Pipe(14mm)
*Removed O2 Sensors (22mm Wrench)
*Removed Fan Assembly(10mm)
*Removed Front Heat Sheild(10mm)
*Removed Front Manifold(14mm)
*Installed Front Header
*Installed Fan Assembly
*Removed Rear O2 Sensor(22mm)
*Removed Intake Manifold & Components(8, 10, 12 & 14mm + Pliers)
*EGR Nut on Manifold(24mm)
*EGR Nut at Valve(Adj. Wrench)
*Removed Rear Heat Shield(10mm)
*Removed Rear Manifold(14mm)
*Installed Rear Header
*Installed EGR Tube
*Installed Intake & Components
*Installed Mid and Rear Flex Section Exhaust Pipe(new bolts 5/8")
Problem Areas:
EGR tube nut: Time consuming because of lack of space to turn wrench
Rear manifold heat shield: What a pain. Finally bent it out of the way enough to remove rear manifold then removed them together.
O2 Sensors: The front manifold O2 went in without a problem. The rear....It never made it in Sunday night. It seems the threads were a little small for the sensor, so I had to take it to a muffler shop today.
Other than this everything was smooth. Fitment was perfect.
Results:
The sound is unbelievable. I expected the exhaust to be louder, but it is actually quieter inside under normal throttle and at idle. At WOT, the engine starts to really sing. It's not deeper, but a very harmonious whine. It sounds completely different now. A++ on the beautiful music the VQ now makes.
I haven't had much time to really test them out, but power is definitely increased after 5000rpm. The VI switchover is now much more pronounced and it has a slightly different tone. They seem to be responding very well together. I'll be able to be more specific with a couple of days of driving.
Dyno will come Friday and the track will be Saturday. I can't wait to see how well they will respond to the nitrous.
Sorry for the vague how-to, but I will answer any questions you have.
Matt
Old Nov 3, 2003 | 11:32 PM
ivelweyz
nice, can't wait for the dyno graphs. Do you have a before dyno???
Old Nov 3, 2003 | 11:34 PM
dkmaxitus's Avatar
Dude!!!! It looks sweet. I can't wait for the dyno and track times.
Old Nov 4, 2003 | 12:13 AM
Iron Lung's Avatar
I dynoed back in March, should be a good reference as long as its the same type of machine. I have put a dynomax muffler on since then, but it shouldn't make much difference.
Old Nov 4, 2003 | 12:16 AM
mforrest100's Avatar
I hope you do have a before dyno. It would really help if we new your numbers before you installed the headers so we can actually see how much power you gained.
Old Nov 4, 2003 | 04:00 AM
Max4Speed's Avatar
www.autotalk.com
Cant wait for the dyno.
Old Nov 4, 2003 | 04:06 AM
Jshock1's Avatar
looks nice man can't wait to see your numbers
Old Nov 4, 2003 | 04:47 AM
BEJAY1's Avatar
Conecarver
Thanks for dynoing for everyone. You had one of the strongest engines even before doing this. Now it'll just be
Old Nov 4, 2003 | 05:47 AM
AltiMAX's Avatar
[QUOTE=Iron Lung]I dynoed back in March, should be a good reference as long as its the same type of machine. I have put a dynomax muffler on since then, but it shouldn't make much difference.
I was checking out your cardomain home page, and I think your car looks AWESOME!!. Everything from your dual exhaust setup (with the extra cutout in your Stillen rear valence) to your choice of black chrome in the ROH wheels really do make your car stand out. Can't wait to see the dyno. You make the install sound fairly simple. Is this something anyone who can follow instructions should be able to do (Do they even come with instructions ??) Or is it recommended for someone with moderate mechanical experience ??
Old Nov 4, 2003 | 06:32 AM
nismos14's Avatar
§è~® f®ÈÄk
sweet. can't wait for dyno results
Old Nov 4, 2003 | 07:31 AM
MAXimumHP's Avatar
Nice
Nice to here the rear manifold wasn't quite as bad as was heavily rumored on this site.
Old Nov 4, 2003 | 07:33 AM
Dave B's Avatar
Not DAVEB the parts guy
Is removing the intake manifold really necessary. According to Cattman's directions, removing the engine cradle brace is the key to much of the rear manifold.
I'm looking forward to the dyno.
Dave
Old Nov 4, 2003 | 08:36 AM
Stephen Max's Avatar
Thanks for the write-up. This is my next mod.
Old Nov 4, 2003 | 08:38 AM
mzmtg's Avatar
Minister of Silly Walks
Dave
He probably wanted to have access from the top as well as the bottom. That may make it quite a bit easier if you're doing the install without a lift.
Old Nov 4, 2003 | 08:56 AM
Sprint's Avatar
Originally Posted by Iron Lung
Matt
holy **** .. your name is matt too
Old Nov 4, 2003 | 09:04 AM
Iron Lung's Avatar
It is not impossible, but some type of experience is recommended. If you want to try it(especially removing the intake) be sure to label all bolts and wiring for a much easier experience. Also be sure that you are firmly seated with the socket/wrench when removing the manifold bolts. Thanks for the compliments!
I didn't recieve any instructions, but I installed hotshot headers on a 3.5 Alti last weekend. It was very similar in the amount of space. I removed the manifold from underneath and it was a PIA removing the heat shield and top manifold bolts, so with my car I decided the easiest access was from the top. Although it may have taken a bit longer, it was MUCH easier.
Old Nov 4, 2003 | 09:22 AM
maxima105's Avatar
Headers look Great....can't wait to see the results!!!
Old Nov 4, 2003 | 09:24 AM
Y2KSESteve's Avatar
Sound = Teh Awesome.
Old Nov 4, 2003 | 10:12 AM
Iron Lung's Avatar
Thanks man, and thank you for helping me! Maybe tonight or tomorrow we can take some sound clips/vids?
I put a few more random pics of the install on my homepage(2nd page).
Old Nov 4, 2003 | 10:16 AM
nismology's Avatar
I noticed the "before" dyno you posted is pre-MEVI so we won't really get a good idea of what the gains really are unless you take it off and dyno again...
Old Nov 4, 2003 | 10:29 AM
stephenlc's Avatar
Wow I can't wait to see what kind of gains you get. I am too poor to afford these!
Old Nov 4, 2003 | 10:34 AM
Iron Lung's Avatar
Actually that is with the VI. It looks like it drops like one without, but it is about 25 more horsepower at @6300. I'll try and find my old dyno.
Old Nov 4, 2003 | 10:45 AM
optimus310's Avatar
WOW Matt I didn't even know you got headers dude. Can't wait to see your car at the track, smiking all those GTP's.
Will see you on Sat.
Old Nov 4, 2003 | 10:49 AM
I30tMikeD's Avatar
Just does not look like most VI dyno's I have seen. Shouldn't you be making your peak power at 6100 rpm's or so with the VI, not 5500?
Dave B's VI dyno
http://images.cardomain.com/member_i...675_9_full.jpg
Old Nov 4, 2003 | 10:52 AM
Iron Lung's Avatar
I would think so too. Maybe the stock muffler was choking it up top?
Old Nov 4, 2003 | 10:54 AM
I30tMikeD's Avatar
or maybe your VI was not opening?? Look at Dave B's VI dyno in my above post
Old Nov 4, 2003 | 11:17 AM
Y2KSESteve's Avatar
Regardless his VI is working fine now and I can attest to that. The dyno should be done by Friday and Saturday is the track.
Old Nov 4, 2003 | 11:19 AM
Dave B's Avatar
Ironlung's MEVI is very strange because it really is no different than a US-spec intake manifold dyno. His power peak is at ~5600rpms and then falls off very quickly. All MEVI dynos I've seen have peak power occuring at 6100rpms with little or no change in power until around 6700rpms. On my pre-JWT ECU dyno, my car made 189fwhp@6100rpms and 184fwhp@6500rpms. My dyno was with the stock muffler and hybrid intake. I've seen dynos for MEVI's with CAIs and power falls off a bit quicker after 6100rpms, but nothing terribly dramatic.
I'd have to say Ironlungs MEVI wasn't opening on that run. It still doesn't explain the massive power and torque his setup is making over other MEVI setups (no JWT ECU). His torque numbers are 15-20fwtq higher than anyone else's with just the MEVI and no JWT ECU. Very strange. To me the dyno looks like a US-spec intake manifold with the JWT ECU judging from the shape of the curves and numbers (the plot looks just like Jeff K's JWT/USIM dyno). 190fwhp/200fwtq is very typical for those setups. Of course this dyno could just read a bit higher than most others because not all dynos spit out the same kinds numbers. Bejay makes some huge power on the dyno with his 4th gen, but he runs 14.7s@93mph which is pretty typical.
Dave
Old Nov 4, 2003 | 11:27 AM
KsuMax's Avatar
Cheesing away...
The look really good.
Old Nov 4, 2003 | 11:34 AM
MyownNismo's Avatar
Future Camaro SS owner
5th Genner here interested in your dyno.
Old Nov 4, 2003 | 12:02 PM
Y2KSESteve's Avatar
I'll be getting these headers for my 2k hopefully in no more than 2 weeks.
Old Nov 4, 2003 | 12:49 PM
cscm094's Avatar
vid tape the dyno so we can hear the sweet harmony of VQ music
Hope to hear your new exhaust note soon!
Old Nov 4, 2003 | 12:52 PM
Iron Lung's Avatar
Here is the stock manifold dyno. The curves are similar, but you can see that there is a good bit more power after 6000 with the VI dyno, even with a more restrictive exhaust. It still is unlike any other VI dyno. Maybe there was a small vacuum leak that caused it to drop slowly?
Old Nov 4, 2003 | 01:47 PM
NissanSE98's Avatar
how much? how much? $$$
Old Nov 4, 2003 | 04:39 PM
Nealoc187's Avatar
SLOW
Dang it's too bad we don't have what I would call a "normal" dyno from beforehand. Your dyno is so much higher than mine it's rediculous.
also a comment you made caught my eye, you said "as long as its the same type of dyno it shouldn't matter..." are you saying that you are not dynoing on the same machine as you did before? In theory you are correct, however in practice this is far from the case I've found. So there are going to be 2 issues here, one is that your car already out-dynos just about every other bolt on maxima out there, and two, it doesn't sound to me like you will be dynoing on the exact same machine as before which won't make for as much consistency as one might hope for.
All that crap aside, those headers look awesome under there and I sure do hope they give you nice gains. If I were in the market for headers I'd probably buy a set... but I'm not
Old Nov 4, 2003 | 05:29 PM
BEJAY1's Avatar
Conecarver
Dave
Not to get off topic but this month I'm gonna run both a Dynojet or two and a Mustang to compare figures. I'm curious as to the differences and what I'm really putting down.
Old Nov 4, 2003 | 05:30 PM
mrnock's Avatar
which dynomax muffler do you have, exactly?
Old Nov 4, 2003 | 05:58 PM
96sleeper's Avatar
A few people do read clubsi.com you know right?
Old Nov 4, 2003 | 06:36 PM
I30tMikeD's Avatar
Busted hahahaah
Old Nov 4, 2003 | 07:59 PM
Iron Lung's Avatar
I figured that if it was the same type of dyno(dynojet) it would be the same specs/calibration. I'm not really knowledgeable about them. Hopefully we will be able to see something.
Maybe we can get Y2KSESteve to dyno before hand. He is going to be getting them soon. That should give us a good idea of what they are worth. Oh well at least I'll have a baseline for the cams.
Its the "super turbo"(lol) dynomax. It was fairly inexpensive, but it is a quiet muffler.
how much?
I believe they are @$750.
